23/08/2021, 08h46 | #1 |
Pouvoir de réputation: 22 |
PassThru de diagnostic Xentry 12.2021 Torrent, mega
Configuration requise: Windows 7, 10 64 bits Taille: 19 Go Programme de diagnostic automobile concerne Mercedes-Benz Ce programme fonctionne avec un appareil comme:
Dernière modification par Aleksey-MS ; 28/11/2021 à 14h25. |
The Following 38 Users Say Thank You to Aleksey-MS For This Useful Post: | AlexBr34 (04/10/2021), alexteamktm (23/08/2021), attefco (08/03/2023), aujibe (24/01/2024), autodiagauto (28/11/2022), baso123 (30/01/2024), Bollide (18/11/2021), boumediene (24/08/2021), brudu1327 (25/07/2022), Cameleons13 (07/05/2022), Christou (22/02/2024), curtis50 (18/02/2024), ElTurco (31/10/2022), geekus357 (30/01/2024), hicham075 (08/12/2023), ishams2002 (05/09/2021), j-sky (29/11/2021), khalil84 (02/12/2022), Mcsdiag (27/08/2021), mingego (19/03/2023), Minimox (23/08/2021), moky (01/02/2022), NewSmart (17/07/2022), o0cimbom0o (27/12/2021), ochy9200 (02/03/2024), Omar27 (28/11/2022), raptor95 (15/07/2022), Seev59 (19/07/2022), snartrory (26/06/2022), speedy_bou (27/08/2021), valanzasco (26/12/2023), vince11 (03/05/2022), vortex (23/08/2021), xav2a (19/02/2023), yahiadiag (25/08/2021), yann3 (25/08/2021), Yolit (03/06/2023), zenata (07/09/2021) |
23/02/2022, 08h57 | #2 |
Ajout de la nouvelle version Xentry Diagnosis PassThru 03.2022 méga
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
The Following 5 Users Say Thank You to Aleksey-MS For This Useful Post: | autodiagauto (28/11/2022), NewSmart (17/07/2022), Seev59 (19/07/2022), vortex (23/02/2022), zenata (28/10/2022) |
07/06/2022, 15h40 | #3 |
Added Xentry Passthru 22.6.3 (06.2022)
The Following 4 Users Say Thank You to Aleksey-MS For This Useful Post: |
17/07/2022, 18h06 | #4 |
Pouvoir de réputation: 8 |
Bonsoir
suite a nos échange sur: Xentry OpenShell 12.2021 HHT (+C3) ( https://www.tlemcen-electronic.com/f...d.php?t=102480 ) je me suis décider a acheter le Openport2.0 recu ce jour pour remplacer mon MB StartDiag C3 Merci du Partage bonne fin de journée
Le partage d'une passion commune : l'automobile |
The Following User Says Thank You to NewSmart For This Useful Post: | ochy9200 (02/03/2024) |
18/07/2022, 22h30 | #5 |
bonsoir il faut un nouveau KeyGen ?
car avec "Xentry Advanced KeyGen 1.1" j'ai désactiver activer boot secure et réussi a activer : Xentry OpenShell 12.2021 HHT (+C3) qui n'est pas compatible avec Openport2.0 en mettant dans le keygen HWID , APPID , date et Lic Num (11) je suis sous win 10 Pro 64Bit je viens d'installer Xentry Passthru 22.6.3 (06.2022) je teste avec le même keygen avec : HWID: 46A8D740A761 APPID: 252 Lic Num: 11 ( j'ai également essayer avec d'autre chiffre ) mais cela me dit que: le StarKey mis a disposition n'est pas valide est ce que j'ai louper quelquer chose ou c'est le keygen qui n'est pas le même pour activer : Xentry OpenShell 12.2021 HHT (+C3) et Xentry Passthru 22.6.3 Merci Beaucoup bonne fin de soiree
19/07/2022, 05h59 | #6 | |
19/07/2022, 10h01 | #7 | |
Pouvoir de réputation: 17 |
Il faut supprimer ton ancienne clé "lic_key_2.dat" dans ce dossier : C:/ ProgramData/ LicDir/ Puis refaire l'activation |
The Following User Says Thank You to ToNy68 For This Useful Post: | NewSmart (19/07/2022) |
19/07/2022, 13h01 | #8 | |
j'ai oublier de le marque mais le dossier LicDir et vide et j'ai également mis date de fin 2034 soit j'ai louper quelque chose soit j'ai pas le keygen j'ai lu pour une precedente version qu'il fallait surement patcher l'installation avec un dossier medicine + supprimer un fichier (com.Daimler....) merci beaucoup
19/07/2022, 16h17 | #9 |
Applique ce patch aussi. Sinon passe moi ton teamviewer que je regarde |
20/07/2022, 11h22 | #10 |
merci beaucoup cela a résolu mon problème d'activation tu es un chef
21/07/2022, 19h47 | #11 |
Bonsoir
je viens de prendre le temps d'essayer xentry passthru et openport 2.0 je fais un petit retour si jamais cela peux aider certaines personnes dans leurs choix de VCI il semblerait que OpenPort 2.0 ne soit pas compatible Kline donc communique uniquement avec le calculateur moteur Tester sur mes deux Smart 452 et 450 : - Reconnaissance du VIN : ne fonctionne pas ducout je rentre le VIN Manuellement - Calculateur moteur : lecture ok effacement des erreurs semble ok - Compteur : pas de communication - SAM : pas de communication - AirBag : pas de communication - Direction Assister : pas de communication je vais essayer de me trouver un VCI compatible Kline je suis entrain de me renseinger sur le VXDIAG VCX SE si vous en avez un a me conseiller je suis preneur Merci Passez une bonne soirée
22/07/2022, 07h28 | #12 | |
22/07/2022, 11h21 | #13 | |
ok merci beaucoup je vais me m'orienter vers le C4 pour remplacer mon C3 Super Partage : "PassThru de diagnostic Xentry 12.2021" fonctionne très bien et très fluide juste dommage que le VCI OpenPort 2.0 ne prend pas en charge KLINE Merci encore passer une bonne journée
22/07/2022, 11h25 | #14 | |
28/10/2022, 20h30 | #15 |
Added Xentry Passthru 22.12.1
Pack Xentry Passthru 03.2021 + Keygen | SaTouF | MBStar, Xentry, DAS | 29 | 27/02/2023 19h11 |
Machines de diagnostic Mercedes Xentry Passthru 2019 | omarzoro | Vente, Achat, Echange | 4 | 28/10/2021 16h07 |
Xentry Passthru OpenShell 2021.06 | boukrama | MBStar, Xentry, DAS | 1 | 09/06/2021 18h51 |
Xentry Diagnostic Open Shell/Xentry Diagnostic Passthru ( Full Solutions ) | SRA | Vente, Achat, Echange | 0 | 10/09/2020 14h29 |
XENTRY DIAGNOSTIC PASSTHRU 2018 torrent | mod-files.com | MBStar, Xentry, DAS | 7 | 12/03/2019 20h56 |
