Vieux 12/11/2024, 17h33   #1
NAAJ
Avatar de NAAJ
NAAJ is on a distinguished road
Par défaut Besoin code abs pour mk6
Saturday,09,November,2024,1109:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 23.3.1.0
Data version: 20230421 DS346.2
Ross-Tech: Home
VIN: WVWZZZ1KZAW058290 License Plate:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZAW058290 Mileage: 138640km-86146miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 AH HW: 03L 906 022 G
Component: R4 2,0L EDC G000AG 3892
Revision: 13H02--- Serial number:
Coding: 0000078
Shop #: WSC 00191 264 15243
VCID: 6BD572AB4A85F9CB0E-803E
VINID: 9E69EAAAA05BA919C014808900E36A35F6
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2211
Revision: 05151112 Serial number: 00001006101407
Coding: 0000020
Shop #: WSC 02069 000 90108
VCID: 183F7D672B93A25313-804C
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 00066 000 00000
VCID: 04073917871B16B3EF-8050
5 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
01042 - Control Module; Not Coded
000 - -
01486 - System Function Test Activated
000 - -
00778 - Steering Angle Sensor (G85)
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5K0 907 044 BD HW: 5K0 907 044 BD
Component: Climatronic H14 0608
Revision: 00003001
Coding: 0000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 6ED37BBFB1970CE329-803A
2 Faults Found:
13701392 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
9481200 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 E HW: 1K0 937 086 E
Component: BCM PQ35 M 103 0537
Revision: 00103 AC
Coding: 40180A3EF8371AC040080080540081EC43511588736D856064 8000200000
VCID: 326BAFCF6D2F68030D-8066
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 30060 21 0501
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 020709 05 54 0402
Coding: 0330AD
15 Faults Found:
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
02746 - Bulb for Daytime Running Light; Right
00978 - Lamp for Low Beam; Left (M29)
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus - Intermittent
01496 - Bulb for Fog-Lamps; Left (L22)
01315 - Transmission Control Module
004 - No Signal/Communication - Intermittent
02395 - Parking Light Front Right (M3)
01598 - Drive Battery Voltage
011 - Open Circuit - Intermittent
01309 - Power Steering Control Module (J500)
00987 - Lamp for Brake Light; Left (M9)
007 - Short to Ground - Intermittent
00988 - Lamp for Brake Light; Right (M10)
01504 - Bulb for License-Plate Light (X)
014 - Defective - Intermittent
00907 - Intervention load Management
000 - - - Intermittent
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88530914704083
Coding: 10010A
VCID: 408FF507D383CA938B-8014
6 Faults Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
009 - Open or Short to Ground
01543 - Parking Aid Warning Chime (H15)
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 035 0604
Serial number: 003C2RA0XNR8 Dataset Number: 5K0003v____ 0066
Coding: 00003139
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77FD5EDBCECD4D2BFA-8022
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V U01 ----
Serial number: 3C647249ZZZZZZZZZZZZ
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V U01 ----
Serial number: 1F507049ZZZZZZZZZZZZ
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 22212E24ZZZZZZZZZZZZ
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 18052E00ZZZZZZZZZZZZ
1 Fault Found:
12656896 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001034
VCID: 020B3F0F5D0F1883DD-8056
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 870 E HW: 5K0 920 870 E
Component: KOMBI H05 0206
Serial number: 00000000000000
Coding: 170900
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2F6DA6BB761D45EB62-807A
2 Faults Found:
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 260609F2000144
Coding: EDA07F0E000202000002
VCID: 66C3039F5167C4A351-8032
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H05 0206
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 5K0 959 701 E HW: 5K0 959 701 E
Component: Tuer-SG 009 2123
Coding: 0004278
VCID: 3467A9D7573B66331F-8060
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 70 2901
Revision: 00H17000
VCID: 2F6DA6BBBE1D45EB62-807A
4 Faults Found:
16353 - Control Module - Internal Malfunction
014 - Defective
16355 - Control Module - Watchdog Timer
014 - Defective
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Component: Tuer-SG 009 2109
Coding: 0004534
VCID: 3365AACB5235610B06-8066
2 Faults Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 56D 035 190 A HW: 56D 035 190 A
Component: RCD510USBRVC 002 0003
Revision: -----001 Serial number: VWZ4Z3R8010978
Coding: 01000424040005
Shop #: WSC 00078 790 00186
VCID: 224B5F8F3DCFF883FD-8076
1 Fault Found:
00625 - Vehicle Speed Signal
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
VCID: 356194D35C417F3B28-8060
Address 76: Park Assist
Cannot be reached
End---------------------(Elapsed Time: 03:07, udsna)-----------------------
NAAJ est déconnecté   Réponse avec citation
Vieux 02/12/2024, 15h29   #2
NAAJ
Avatar de NAAJ
Y t'il quelqun pour me donner la code long abs pour cette vin j'ai pas encore trouvé de solution
Vieux 25/12/2024, 19h15   #3
fen + 1
Avatar de fen + 1
fen + 1 will become famous soon enoughfen + 1 will become famous soon enough
Salut, tu n'as pas réussi à le lire avant de le changer ?
Tu as besoin d'un code d’accès pour changer le codage ?
Seb
fen + 1 est déconnecté   Réponse avec citation
5k0, address, component, intermittent, status
besoin d'un code démarrage pour Mégane 1 mysterauto Transponder, code pin 2 11/11/2018 20h55
Besoin de code pour un Delphi RCD510 VWPassat31 Autoradio et Navigateur GPS 6 21/10/2018 13h39
Besoin code pin pour faw aloula17 Transponder, code pin 5 26/09/2018 14h51
besoin d'aide pour payer un code pour refaire une cle d'une peugeot 307 ADSA programmation & synchronisation de clé 14 19/10/2016 22h22
besoin code PIN pour peugeot 307 edc16c34 PIC16F84 Transponder, code pin 19 07/09/2015 02h46
Fuseau horaire GMT +1. Il est actuellement 10h48.
