Vieux 07/11/2018, 04h15   #1
bbert90
Avatar de bbert90
bbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to behold
Par défaut PROBLEME boite clio 3 1.5 DCI
bonjour j ai une panne blizzard la voiture ne s eteint plus et ne demarre plus si ont ne mets pas la marche arrière ont dirais qu elle est passer en boite auto si vous avez une idee MERCI
bbert90 est déconnecté   Réponse avec citation
Vieux 07/11/2018, 10h13   #2
abdel93
Avatar de abdel93
abdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant futureabdel93 has a brilliant future
slt tente de faire syncro boite qui sai petétre que tout rentrera dans l'ordre
bbert90 (07/11/2018)
Vieux 07/11/2018, 11h04   #3
Binbin
Avatar de Binbin
Pouvoir de réputation: 42
Boite auto ou manuel?
Vieux 07/11/2018, 12h29   #4
vv58
Avatar de vv58
Pouvoir de réputation: 23
vv58 has much to be proud ofvv58 has much to be proud ofvv58 has much to be proud ofvv58 has much to be proud ofvv58 has much to be proud ofvv58 has much to be proud ofvv58 has much to be proud ofvv58 has much to be proud ofvv58 has much to be proud ofvv58 has much to be proud of
salut d apres ce que je comprends boite manuel regarde ton contacteur m ar sur la bv sinon voir au diag uch et upc si les parametres position neutre ou autre correspondent
mais quand meme a verifier s ils sont bien present
The Following User Says Thank You to vv58 For This Useful Post:
Vieux 07/11/2018, 12h49   #5
michelméca
Avatar de michelméca
michelméca is a glorious beacon of lightmichelméca is a glorious beacon of lightmichelméca is a glorious beacon of lightmichelméca is a glorious beacon of lightmichelméca is a glorious beacon of light
bonjour, controle les états des capteurs des pédales souvent défectueux avec clip
michelméca est déconnecté   Réponse avec citation
The Following User Says Thank You to michelméca For This Useful Post:
Vieux 07/11/2018, 16h57   #6
bbert90
Avatar de bbert90
MERCI A TOUS default df001 CIRCUIT COMMANDE RELAIS +12 APC C EST UNE BOITE MANUEL LA EST ELLE demarre normal mais faut mettre la marche arriere pour l éteindre avec la clef avent y falais aussi mettre la marche arriere pour demarrer dans les etas elle est bien en mode manuel il y a un + 12V QUI alimente toujours le boitier UPC je pense ? upc changer uch changer pris sur une boite manuel pareil meme si je debranche le neiman ellle coupe pas ?
Vieux 07/11/2018, 17h40   #7
Binbin
Avatar de Binbin
Boisoir,
Pour moi, il y a un problème d'isolement quelque part, le 12V APC est'il donné par un relais démontable, voir si il ne reste pas collé?
La masse du boitier UPC, est elle correct?
Vieux 07/11/2018, 18h06   #8
Binbin
Avatar de Binbin
Peut être un court circuit entre contacteur Marche AR et contacteur point mort, ou inversion de la connectique.
Vieux 07/11/2018, 18h17   #9
vv58
Avatar de vv58
salut sur clio 3 avec clé (pas a carte c est different) un apc vient du neiman passe par un fusible de souvenir 15A dans support fusible int et donne l info a uch que tu as contact ou pas j ai deja eu un fusible qui merdait et la voiture clé enlevé du neiman tournait toujours ou pas de demarrage et c est visible par un parametre uch avec clip forcement c est pas ça ta panne mais il faudrait deja voi si ce parametre apc est bon a la clip et apres avancé vers upc
Vieux 07/11/2018, 18h51   #10
bbert90
Avatar de bbert90
merci de vos réponse oui les parametre sont correcte au clip les relais ont ete changer et les fusible aussi au début elle demarais pas tu débranchais le moins de la batterie et elle demarais demais je vais voir quelle + se coupe sur le boitier de fusible quand ta la marche arriere enclenche merci
---------- Post added at 19h51 ---------- Previous post was at 19h48 ----------
c est le relais injection qui reste alimente
Vieux 09/03/2024, 19h24   #11
modusbleue
Avatar de modusbleue
modusbleue is an unknown quantity at this point
Désolé pour le déterrage mais j'ai exactement le même problème sur une modus 1.5 dci.
Auriez-vous trouvé d'où vient le problème ?
Merci.
Bonne soirée.
modusbleue est déconnecté   Réponse avec citation
problème boite edc4 clio RS star31 Boite de vitesse 22 25/04/2018 18h55
voyant boite auto clio 2 mindouza ABS, ESP, DSC 6 12/12/2017 08h53
clio 1 boite auto ne s'arrete pas soustourou Automobile en général 2 12/08/2017 18h34
Problème A6 v6 tdi problème suite a passage boite auto a manuel micka45 Mécanique générale 0 11/11/2015 12h20
changer boite vitesse clio 1.9 d 2000 nas33 Renault, Dacia, Nissan 7 08/11/2015 19h00
Fuseau horaire GMT +1. Il est actuellement 02h15.
