Vieux 20/07/2015, 05h29
Drogo
V.I.P
Avatar de Drogo
Pouvoir de réputation: 90
Drogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond repute
Hello,
entrer votre pin actuel celui de votre voiture pas celui de la pompe provenant d'un autre vehicule .
Code:
Diesel Pump Programming
Astra-G / Zafira-A
Donor-car
Remove dieselpump from donor-car
Attention:
You will need donor-car's Security Code!
Car where donor pump needs to be installed
Install dieselpump in the car
Set up communication with ECM
Select
[Programming]
Select
[Reset ECU]
Enter donor-car's Security Code
This will reset the previously learnt security code. Then, your engine ECU (which is inside the
pump) will be resetted, so you can learn it to the new car.
Set up communication with Immobilizer module
Select
[Programming]
Enter Security Code of car where you have installed the dieselpump
Select
[Immobilizer Function Programming]
Select
[ECM (Motor Module) replaced]
This will learns the new Security Code to the engine control module.
Astra-G and Zafira-A can also be installed with a VP44/PSG5 for Y20DTH. These PSG5 units
ESPERAR E SABER ESPERAR É UMA GRANDE VIRTUDE
Dernière modification par Drogo ; 20/07/2015 à 06h04.
Drogo est déconnecté   Réponse avec citation
