Discussion: formation winols
Vieux 09/06/2017, 14h13
Kennfeld
Avatar de Kennfeld
Pouvoir de réputation: 26
Kennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud of
Nouvelles fonctions dans ols entre autre Xor
* Changed Items Version Date
New New: Hotkey Ctrl+Shift+Alt+2 to connect with compare with original values 3.86 07.06.2017
New ConnectBar buttons +/- are strong when Shift/Shift+Ctrl is pressed 3.86 07.06.2017
New LUA: new parameter for projectGetProperty 3.86 07.06.2017
New LUA: binaryand, binaryxor 3.86 07.06.2017
New Massimport of zipped ols files is now supported 3.86 07.06.2017
New Editing: Not only individual cells, but ranges can now be delselected 3.86 07.06.2017
New PrjProperties: Delphi detection improved 3.86 07.06.2017
New RAR-Component updated 3.86 07.06.2017
New Improved: Detection for IntelHexBin PHF files 3.86 07.06.2017
New Overview data now updated after Damos/Ecfg import 3.86 07.06.2017
Fixed Crash during mass export 3.86 07.06.2017
Fixed HighDPI: in 2d mode the lower bar was scrolled wrong 3.86 07.06.2017
Fixed When inserting %-values factor/offset of the arget map were ingored 3.86 07.06.2017
Fixed Export-Dialog: Adress range was initialized wrong upon repeated export with elements 3.86 07.06.2017
Fixed Export problems when import folder should be used by default 3.86 07.06.2017
Fixed Wrong offset calculation upon kp import 3.86 07.06.2017
Fixed Graphic bugs in 2d with N and HighDPI 3.86 07.06.2017
Fixed Connect window was moved when changing bit width 3.86 07.06.2017
Fixed MouseWheel-Scrolling didnt work well with some touchpads 3.86 07.06.2017
Fixed PrjProperties: Error with dropdowns with vertically stacked displays 3.86 07.06.2017
Fixed Problem when connecting with changing the endian while a differnt endian was not allowed 3.86 07.06.2017
Fixed Problem with axis detection before map 3.86 07.06.2017
Fixed Problem with connect map and display scaling 3.86 07.06.2017
Fixed Scrolling text mode was very slow with large map consisting only of zeros 3.86 07.06.2017
Fixed Ctrl+Alt+Shift P (Toggle pot. map display) didnt work any more 3.86 07.06.2017
Fixed Ctrl+Shift+2 ignored connect-orignal-presed 3.86 07.06.2017
Fixed LUA: projectSetAt didnt work for very large numbers 3.86 07.06.2017
New Scripts: sort column headers 3.85 04.05.2017
New Automatically detect axis before map for 1d 3.85 04.05.2017
New Save the current cursor position after 1.5s on the stack for Alt+Left (= Back) 3.85 04.05.2017
New EditAsText: Center the selected line in the hexdump 3.85 04.05.2017
New Faster: Create map if many map are already open 3.85 04.05.2017
New Faster: Sort in EditAsText 3.85 04.05.2017
New Cummins IntelHex files can be directly imported 3.85 04.05.2017
New PrjOpen: Build popup now grouped 3.85 04.05.2017
New Map sidebar: map description now also in the tooltip 3.85 04.05.2017
New New function: Selection > Selection from clipboard 3.85 04.05.2017
New PS calculation in PrjProperties and in window menu 3.85 04.05.2017
New Improved: recognition PrjProperties 3.85 04.05.2017
Fixed Crash when viewing images in project comment 3.85 04.05.2017
Fixed Bosch8-KF was detected in 16-bit selection 3.85 04.05.2017
Fixed Edit multiple maps => Original does not work with paired projects 3.85 04.05.2017
Fixed Hex search for 0xBB did not work 3.85 04.05.2017
Fixed End connecting by closing window => Not all information has been reset 3.85 04.05.2017
Fixed Connect by shift+icon did not adjust data organization 3.85 04.05.2017
Fixed Sometimes wrong cursor position with scaled monitor setting 3.85 04.05.2017
Fixed Paste on last byte of the project did not work 3.85 04.05.2017
Fixed Problems with PatchTag block in Polish / Russian version 3.85 04.05.2017
Fixed Shift+Insert does not work (Windows default alternative for Ctrl+V) 3.85 04.05.2017
Fixed Title of a map could be hidden on the left 3.85 04.05.2017
Fixed Unsaved changes to the project properties were ignored when opening new versions 3.85 04.05.2017
Fixed Copy values from HiLo to LoHi map did not work with negative values 3.85 04.05.2017
Fixed Blk load did not work properly anymore 3.85 04.05.2017
Fixed Kp-Import: Crash 3.85 04.05.2017
Fixed Kp-Import: Addresses were partly incorrectly imported 3.85 04.05.2017
Fixed Change of the PrjStatus has not updated the write protection for all open versions 3.85 04.05.2017
Fixed ImportWiz: Dialog could show 0% with version import if there were very few differences 3.85 04.05.2017
Fixed ImportWiz: Prj property search does not always trigger during import 3.85 04.05.2017
Fixed OpenPrj: Viewing the project properties caused an error message for reseller folders 3.84 06.04.2017
Fixed Some older ols-files could not be read any more 3.83 05.04.2017
Fixed Customer number was ignored when importing an ini file 3.83 05.04.2017
Kennfeld est déconnecté   Réponse avec citation
