Discussion: 106 xsi - MP3.1
Vieux 02/03/2021, 16h26
boul27
Avatar de boul27
boul27 is a name known to allboul27 is a name known to allboul27 is a name known to allboul27 is a name known to allboul27 is a name known to allboul27 is a name known to all
Par défaut 106 xsi - MP3.1
Hi all,
Here is my job about motronic mp3.1
Hardware 0261200217
Software 1267357551
Original bin attached
ols project can be added if needed
I used the infamous map of maps to list all the maps (6300 to 63D5)
Need to find some factor, spark adavance, fueling ..etc..
Any help will be welcomed :)
project in french sorry,
allumage --> spark advance
injection --> fueling
rupteur --> rpm limitor
charge partiel --> partial load
ralenti --> idle
For the headers, but some scale may not be good
#0020 - tp : throttle position
#0036 - batt : battery voltage (dec x 0.0704)
#0037 - eat : engine air temp (0.75*dec - 48)
#0038 - ect : engine coolant temp (0.75*dec - 48)
#003B - rpm : engine rev (dec x 40)
#0040 - load8 : internal load (byte)
#0041/42 - load16 : internal load (word)
#0043 - MAP : MAP sensor value
Rev limiter : 937500/Dec
Thank you
Type de fichier : bin FICHIER EPROM ORI 0261200217 1267357551.bin (32,0 Ko, 4 affichages)
boul27 est déconnecté   Réponse avec citation
The Following User Says Thank You to boul27 For This Useful Post:
atlon2 (03/03/2021)
