Vieux 04/03/2017, 20h51   #136
Med1387
Avatar de Med1387
Med1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant future
J'ai le message
Windows vista or above detected making a second patch
Med1387 est déconnecté   Réponse avec citation
Vieux 11/03/2017, 23h49   #137
guyguy307
Avatar de guyguy307
Pouvoir de réputation: 40
guyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond reputeguyguy307 has a reputation beyond repute
BONJOUR
je rencontre un probléme
mn pc win7 32 galetto clone
j'ai exécuter le flash epprom pour le numero de séri.
installer le soft de fantomel
replacer les 2 dll dans systéme 32
et quand je lance galetto par le raccourcit bureau , j'ai une erreur
" cannot find 'fgt2XX.dll'. please re install this application"
auriez vous une idée svp
guyguy307 est déconnecté   Réponse avec citation
Vieux 12/03/2017, 00h27   #138
guyguy307
Avatar de guyguy307
re bonjour
probléme resolut , aprés désistallation et rinstal des driver
maintenant a l'ouverture du soft il me demande un patch pour win7
AVEZ VOUS DEJA EU CE MESSAGE
Vieux 12/03/2017, 00h42   #139
rapou30
Avatar de rapou30
Pouvoir de réputation: 24
rapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud of
Bonsoir , je me rappelle que au tout debut de l'installation tu peut choisir entre 2 window . je cherche le fichier RAR ...
Le piment c'est comme l'autoroute , ca se paye a la sortie
rapou30 est déconnecté   Réponse avec citation
Vieux 12/03/2017, 00h44   #140
INVICTUS
Avatar de INVICTUS
Pouvoir de réputation: 95
salut oui tu as le message d erreur patch etc normal apres le soft ce lance sous windows 7
INVICTUS est déconnecté   Réponse avec citation
Vieux 12/03/2017, 00h58   #141
rapou30
Avatar de rapou30
regarde si ca peut aider
https://www.youtube.com/watch?v=fannX7MMths
Vieux 12/03/2017, 13h47   #142
guyguy307
Avatar de guyguy307
le soft se lance sous win7 mais tout est grisé
j'ai essayer install sous xp
message erreur a l'ouverture "win xp or lower detected , skipping second patch"
l'epprom est bien flasher , driver ok et c'est avec le soft de fantomel que je fait l'install
merci de vautre aide
Vieux 12/03/2017, 19h47   #143
guyguy307
Avatar de guyguy307
RRE BONJOUR
je reformate et re-istalle un win7 et vous tien au courant.
je ne comprend pas pourquoi l'ecran reste grisé
Vieux 12/03/2017, 20h11   #144
INVICTUS
Avatar de INVICTUS
mais non quand cest griser cest normal debranche ton cable usb et rebranche quand tu le lance et tuverra ca marche
Vieux 12/03/2017, 20h26   #145
INVICTUS
Avatar de INVICTUS
pour info de puis le flashage du fgtech sur xp ca fonctionne pas sous windows 7 nikel
Vieux 12/03/2017, 20h55   #146
guyguy307
Avatar de guyguy307
Ok merci je refait linstall et jte dit tout ss merci bien les amis
Vieux 12/03/2017, 22h32   #147
guyguy307
Avatar de guyguy307
win 7 tout frai avec java et framexwork 3.6
soft fantomel installer
les 2 dll coller dans
system
system32
driver installer
maintenant
je connect la sonde
je lance le soft
le message erreur apparait
le relais claque
et erreur "fg tech a cesser de fonctionner "
merci pour votre aide
Vieux 13/03/2017, 18h47   #148
guyguy307
Avatar de guyguy307
BONJOUR
mantenant galetto s'ouvre
l'ecran est toujour griser
j'ai donc décider de flasher le lpc
et j'ai message erreur
"cannot communicate with the test board"
auriez vous une idée ?
Vieux 13/03/2017, 22h35   #149
INVICTUS
Avatar de INVICTUS
les 2 dll faut les coller dans c programme file dossier fgtech et non dans system 32 lami
The Following 3 Users Say Thank You to INVICTUS For This Useful Post:
guyguy307 (13/03/2017), pouettedu76 (13/03/2017), seadoo831 (13/03/2017)
Vieux 13/03/2017, 22h53   #150
guyguy307
Avatar de guyguy307
SALUT
merci de ta reponse
j'avais déja coller dans fg tech ; j'ai renlever de systéme 32 , toujour pareil .
mon galetto doit etre mérdeux lool
si vous avez un eu d'occas bon prix ,
contacter moi en mp
cherche fichier fix pour reanimer fgtech galetto v54 version 04 KKHALIL Logiciel 3 22/01/2019 14h47
logiciel fgtech galetto v54 KKHALIL Logiciel 16 21/01/2019 13h33
Recherche CD Fgtech Galetto v54 seadoo831 Réparation & Programmation des calculateurs 1 29/10/2015 09h37
Modification FGTECH galletto 2 V50 tony76 Flasheur de calculateur 2 03/10/2013 02h47
Fuseau horaire GMT +1. Il est actuellement 01h19.
