Vieux 12/03/2020, 18h40   #16
electro_bordeaux1
Avatar de electro_bordeaux1
Pouvoir de réputation: 31
electro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud of
toujours le meme message pendant la lecture
l union fait la force
electro_bordeaux1 est déconnecté   Réponse avec citation
The Following User Says Thank You to electro_bordeaux1 For This Useful Post:
autodiagauto (12/03/2020)
Vieux 12/03/2020, 18h52   #17
Mook31
Avatar de Mook31
Pouvoir de réputation: 41
Mook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond repute
Ton soft est installé et ton boitier est reconnu, tu as maintenant un problème de lecture.
Tu essaye de lire quoi ?
Mook31 est connecté maintenant   Réponse avec citation
The Following 2 Users Say Thank You to Mook31 For This Useful Post:
autodiagauto (12/03/2020), electro_bordeaux1 (12/03/2020)
Vieux 12/03/2020, 19h06   #18
electro_bordeaux1
merci a tous les particippant a mon sujet probleme resolu c etais probleme de connexion
maintenant ce que je veux savoir c est que le calculateur d origine fiat ducato MJD 8F3.BD et j ai apporter une de la casse MJD 8F2.F2 est ce qu ils sont compatible ou pas?
Vieux 12/03/2020, 21h15   #19
electro_bordeaux1
bonsoir a tous les membres voici mes nouvelles
lorsque je fais la lecture sur le calculateur d ocasion ça passe bien
mais avec le calculateur d origine la lecture ne se fait pas parceque le processeur est deja passer sous l air chaud avec un autre technicien il y a de la patte dessus est ce qu il y a une solution a ce probleme et merci
Vieux 12/03/2020, 21h20   #20
electro_bordeaux1
voici les coordonnees du calculateur
Type de fichier : jpg index4.jpg (7,4 Ko, 13 affichages)
Vieux 13/03/2020, 00h03   #21
electro_bordeaux1
j attend votre aide sur la compatibilité des calculateurs est ce que MJD 8F2.F2 peux fonctionner à la place de MJD 8F3.BD?
autodiagauto (13/03/2020)
Vieux 13/03/2020, 11h15   #22
autodiagauto
Avatar de autodiagauto
Pouvoir de réputation: 43
autodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond repute
Je n'ai tester ce calculateurs MJD 8F2.F2
autodiagauto est déconnecté   Réponse avec citation
The Following User Says Thank You to autodiagauto For This Useful Post:
electro_bordeaux1 (14/03/2020)
Vieux 13/03/2020, 13h03   #23
rapou30
Avatar de rapou30
Pouvoir de réputation: 24
rapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud of
Envoyé par electro_bordeaux1 Voir le message
probleme de telechargement du premier fichier texte
Bonjour , je vous ai envoyé sur MP le fichier texte.
Le piment c'est comme l'autoroute , ca se paye a la sortie
rapou30 est déconnecté   Réponse avec citation
The Following User Says Thank You to rapou30 For This Useful Post:
besoin du soft fgtech v54 2012 nany Flasheur de calculateur 11 09/03/2020 14h22
Besoin info pour cable fgtech v54 reprogauto Flasheur de calculateur 5 08/08/2019 05h24
J ai besoin conseil fgtech dasauto Flasheur de calculateur 10 30/06/2017 21h41
Besoin d aide fgtech galletto v54 nas33 Flasheur de calculateur 10 09/09/2015 22h33
Fuseau horaire GMT +1. Il est actuellement 15h18.
