Vieux 12/10/2014, 20h17   #16
r1lef
V.I.P
Avatar de r1lef
Pouvoir de réputation: 62
r1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond repute
Envoyé par r1lef Voir le message
off sur flash là-dessus ...
Et en OBD en plus , c'est vite vue la dessus !!! Au pire la 5p08 ....
Ip6 R1LEF
Pas de participation = pas de réponse !!! EP+
r1lef est déconnecté   Réponse avec citation
Vieux 24/10/2014, 15h51   #17
stephane
Avatar de stephane
Pouvoir de réputation: 120
stephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond repute
Voilas posté sur ecuserver mais je pense qu'il est très occupé en ce moment donc au cas ou
http://www.tlemcen-electronic.com/fo...008#post241008
merci d'avance
stephane est déconnecté   Réponse avec citation
Vieux 24/10/2014, 18h05   #18
ryosaeba
Avatar de ryosaeba
Pouvoir de réputation: 25
ryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud of
tu n'as toujours pas résolu le problème ladessus ? si c 'est le cas poste la flash
ryosaeba est déconnecté   Réponse avec citation
Vieux 24/10/2014, 23h53   #19
stephane
Avatar de stephane
Non c c'est pour ça que j ais mis le lien plus haut avec le dump
Vieux 25/10/2014, 09h23   #20
fedge
Avatar de fedge
Pouvoir de réputation: 30
fedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud of
Envoyé par stephane Voir le message
Salut.
Reposte ta flash. J' ai pas accés a ton lien.
fedge est déconnecté   Réponse avec citation
Vieux 25/10/2014, 10h58   #21
stephane
Avatar de stephane
Voilas le dump merci a vous par avance
Type de fichier : bin IMMO C8 EDC15C2 29F400BT.bin (512,0 Ko, 7 affichages)
Vieux 25/10/2014, 11h52   #22
SOTISEN
Avatar de SOTISEN
SOTISEN will become famous soon enoughSOTISEN will become famous soon enough
Par défaut Immo off
Salut voila ton off
Type de fichier : bin IMMO C8 EDC15C2 29F400BT-OFFF.bin (512,0 Ko, 17 affichages)
SOTISEN est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to SOTISEN For This Useful Post:
amrougafsa (25/10/2014), delphi38 (25/10/2014), stephane (25/10/2014)
Vieux 25/10/2014, 12h59   #23
stephane
Avatar de stephane
Merci sotisen j essais ça lundi et je te tien au courant
Note perso : grand bonjours au Sénégal qui as bercé mon enfance
Vieux 25/10/2014, 13h50   #24
fedge
Avatar de fedge
Salut.
A tout hasard , un of fait avec le soft d' ecuserver
Type de fichier : bin IMMO C8 EDC15C2 29F400BT-Patched.bin (512,0 Ko, 9 affichages)
The Following 2 Users Say Thank You to fedge For This Useful Post:
amrougafsa (29/10/2014), stephane (25/10/2014)
Vieux 25/10/2014, 15h59   #25
amrougafsa
Avatar de amrougafsa
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
Envoyé par SOTISEN Voir le message
Salut voila ton off
protéger ton fichier frère car je viens de le tester sur un Lancia hdi edc15c2 3 plug sa fonctionne impeccable merci .
amrougafsa est déconnecté   Réponse avec citation
The Following User Says Thank You to amrougafsa For This Useful Post:
Vieux 26/10/2014, 00h04   #26
amrougafsa
Salut voila ton off
je sais pas combien sa coût le petit thanks car ya des gens qui on pas d'argent a acheter .
pardon je dit sa puisque pas mal de fois que je vois beaucoup de téléchargement et petit peut thanks.
stephane (29/10/2014)
Vieux 29/10/2014, 09h39   #27
stephane
Avatar de stephane
Salutation
Vue qu amrougafsa as testé celui de sotisen j ais donc pris celui de fedge zt ca marche nikel merci a tous les deux
The Following 2 Users Say Thank You to stephane For This Useful Post:
amrougafsa (29/10/2014), fedge (29/10/2014)
Fuseau horaire GMT +1. Il est actuellement 05h22.
