Vieux 07/12/2014, 17h48   #31
rosaire974
Avatar de rosaire974
rosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to behold
tiens essai sa l'ami
Type de fichier : zip immo off edc16c3 ok.bin.zip (614 octets, 8 affichages)
rosaire974 est déconnecté   Réponse avec citation
The Following User Says Thank You to rosaire974 For This Useful Post:
Verdun (07/12/2014)
Vieux 07/12/2014, 19h16   #32
Verdun
Avatar de Verdun
Verdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud of
non marche pas la voiture démarre même pas
Verdun est déconnecté   Réponse avec citation
Vieux 07/12/2014, 19h21   #33
Drogo
V.I.P
Avatar de Drogo
Pouvoir de réputation: 90
Drogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond repute
Envoyé par Verdun Voir le message
lis l eprom en full bdm et poste le.
ESPERAR E SABER ESPERAR É UMA GRANDE VIRTUDE
Drogo est déconnecté   Réponse avec citation
Vieux 07/12/2014, 19h25   #34
Verdun
Avatar de Verdun
J ai pas le materiel pour une question si je remet mon fichier d origine est achete un transpondeur vierge est je reencode la cle sa peut marcher
Vieux 07/12/2014, 19h30   #35
Drogo
V.I.P
Avatar de Drogo
j ai essayer le telecodage est bon si je supprimer le dtc dans la carto sa peut régler mon souci ?
Explique pourquoi ta voulu faire le off ?
Vieux 07/12/2014, 19h36   #36
Verdun
Avatar de Verdun
Mon garcon a jeter la cle pa la fenetre la cle c est casse et impossible de retrouver le transpondeur vu que travaille le week end j ai du faire sa pour allez au travaille
The Following User Says Thank You to Verdun For This Useful Post:
Nizar-maoukil (08/12/2014)
Vieux 07/12/2014, 19h52   #37
Drogo
V.I.P
Avatar de Drogo
ci le probleme c est la cle oui sa va marcher .
tu as besoin du code pin , je viens de lire ton fichier original et je trouve ce code
G1KF
je te laisse un video qui montre comment programmer la cle
https://www.youtube.com/watch?feature=player_detailpage&v=XhPgy4VM6IM
The Following 2 Users Say Thank You to Drogo For This Useful Post:
Nizar-maoukil (08/12/2014), Verdun (08/12/2014)
Vieux 07/12/2014, 20h14   #38
Verdun
Avatar de Verdun
Ok je teste demain je te tiens au jus merci encore
Vieux 07/12/2014, 20h32   #39
sofiane78
Avatar de sofiane78
sofiane78 is just really nicesofiane78 is just really nicesofiane78 is just really nicesofiane78 is just really nice
sinon test celui ci
Bon courage!
Type de fichier : zip 206-Patched.zip (714 octets, 5 affichages)
sofiane78 est déconnecté   Réponse avec citation
The Following User Says Thank You to sofiane78 For This Useful Post:
Verdun (07/12/2014)
Vieux 08/12/2014, 09h40   #40
Verdun
Avatar de Verdun
Problème résolu merci a tous pour les dump que vous m avez fourni alors voici comment j ai fait simple acheter un transpondeur vierge et encoder la clé avec le code que paulodoria ma donner et pour les personne qui souhaite faite une off sur un edc16c3 obligatoirement de extraire en full bdm car si vous le fait sur l eeprom 95160 elle se mais en mode dégrader
The Following 3 Users Say Thank You to Verdun For This Useful Post:
Drogo (08/12/2014), Nizar-maoukil (08/12/2014), sofiane78 (08/12/2014)
besoin flash edc16c3 karera 1 Fichiers d'origine, carto, dump, fullbackup 9 13/09/2015 05h41
besoin de immo off pour edc16C3 307 1,4 HDI 8HZ mohcin2 Immobilizer dumps/solutions 14 12/06/2014 13h12
besoin d'aide clonage calclateur edc16c3 mika607 Réparation & Programmation des calculateurs 14 23/10/2013 16h35
besoin immo off calculateur renault mascot edc16C3 95160 electroauto Immobilizer dumps/solutions 8 10/10/2013 20h40
Fuseau horaire GMT +1. Il est actuellement 09h11.
