Vieux 30/03/2018, 23h11   #16
meca
Avatar de meca
meca is a name known to allmeca is a name known to allmeca is a name known to allmeca is a name known to allmeca is a name known to allmeca is a name known to all
Par défaut off100%
slt voici le off 100% fonctionnel sans bridage
ecu sid801 off 100%.rar
meca est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to meca For This Useful Post:
karera 1 (31/03/2018), rahmani2008 (31/03/2018)
Vieux 31/03/2018, 00h35   #17
wscar
Avatar de wscar
wscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to behold
Pose cajai deja fais plusieurs fois cette modif et ca a toujours marché parfait sans rien ni degrade ni rien
Si j ai peu aider n oubliez pas de cliquer sur THANKS!
wscar est déconnecté   Réponse avec citation
Vieux 31/03/2018, 00h37   #18
wscar
Avatar de wscar
dsl g oublier la puece jointe
Type de fichier : bin SID 801 OFF.bin (256 octets, 15 affichages)
The Following User Says Thank You to wscar For This Useful Post:
Vieux 31/03/2018, 07h07   #19
Musta0704
Avatar de Musta0704
Musta0704 has a spectacular aura aboutMusta0704 has a spectacular aura aboutMusta0704 has a spectacular aura about
immo off tester 100%
Type de fichier : rar 93C56 immo off.rar (168 octets, 10 affichages)
Musta0704 est déconnecté   Réponse avec citation
The Following User Says Thank You to Musta0704 For This Useful Post:
Vieux 31/03/2018, 22h06   #20
karera 1
Avatar de karera 1
Pouvoir de réputation: 27
karera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud of
bonsoir a tous retour donc le fichier a meca que je remercie beaucoup nickel pas de mode degrade je voulais savoir j'ai un sid 801 A verssion d'apres ce calculateur ton fichier meca fonctionnel dessus aussi ou pas stp merci !
parfois la solution au probleme et dans la question !
karera 1 est déconnecté   Réponse avec citation
The Following User Says Thank You to karera 1 For This Useful Post:
hatem006 (01/04/2018)
Vieux 31/03/2018, 22h22   #21
meca
Avatar de meca
Négatif je te prépare sa
hatem006 (01/04/2018), karera 1 (31/03/2018)
Vieux 31/03/2018, 22h29   #22
meca
Avatar de meca
Par défaut sid801A
voici bonne prog! nettoyer! souder!
SID801A 93c56 immo offok!.rar
même pass
The Following 5 Users Say Thank You to meca For This Useful Post:
hatem006 (01/04/2018), karera 1 (01/04/2018), rahmani2008 (31/03/2018), tony60 (20/12/2018), VISVAL (20/12/2018)
Vieux 01/04/2018, 02h02   #23
karera 1
Avatar de karera 1
grand merci meca chef thanks !
Vieux 20/12/2018, 20h42   #24
VISVAL
Avatar de VISVAL
VISVAL is just really niceVISVAL is just really niceVISVAL is just really niceVISVAL is just really niceVISVAL is just really nice
salut je peut avoir le pass merci
VISVAL est déconnecté   Réponse avec citation
Fuseau horaire GMT +1. Il est actuellement 19h19.
