Vieux 15/06/2019, 10h32   #16
stephane
Avatar de stephane
Pouvoir de réputation: 120
stephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond repute
salutation oui il faut juste jouez du fer a souder mais sur ton schéma il manque un condo il me semble
je regarde ca toute a l heure
stephane est déconnecté   Réponse avec citation
The Following User Says Thank You to stephane For This Useful Post:
hatem006 (16/06/2019)
Vieux 15/06/2019, 10h44   #17
REDZONE31
Avatar de REDZONE31
Pouvoir de réputation: 82
REDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond repute
tu as deux condo
3X100µf et 4X100nf smd
---------- Post added at 10h44 ---------- Previous post was at 10h43 ----------
ooooppppssss
Envoyé par REDZONE31 Voir le message
tu as au total en condo
Allah se comportera avec toi comme tu te comportes avec autrui
REDZONE31 est déconnecté   Réponse avec citation
Vieux 16/07/2019, 14h24   #18
REDZONE31
Avatar de REDZONE31
SLT STEPH j'ai fini mon montage il me reste juste a programmer le pic16F la je coince impossible avec upa ou avec picprog2009 si quelqu'un peut donner un peut d'aide sa serai sympa merci
Vieux 16/07/2019, 18h04   #19
francab
Avatar de francab
francab is just really nicefrancab is just really nicefrancab is just really nicefrancab is just really nice
Envoyé par hatem006 Voir le message
bonjour a tous,*je revient vers vous si vous connaissez fiat iaw decoder ,une idée sur sa fiabilité et si ya un lien pour l'acheter merci d'avance
Rgarde sur ce lien moi c´est que j´utilise et ça marche bien prix environ 100 euros
https://viaken.pl/pl/dekoder-do-ster...at-ducati.html
francab est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to francab For This Useful Post:
Nextrick (16/07/2019), REDZONE31 (16/07/2019)
Vieux 16/07/2019, 19h09   #20
stephane
Avatar de stephane
Salutations REDZONE je te poste ça dans la nuit je suis pas a la maison pour le moment
Vieux 16/07/2019, 23h05   #21
REDZONE31
Avatar de REDZONE31
Envoyé par francab Voir le message
slt oui tu as raison pour le prix faut pas hésité mais il faut aussi chercher a le faire soit même histoire d’apprendre a évoluer dans monde de l’électronique et ne pas resté au crochet d'un système et ne faire que d'acheté comme sa si tu as une panne tu sera capable de te dépanner par exemple ces mon point de vue en tout cas merci pour ton site que je connais
The Following 2 Users Say Thank You to REDZONE31 For This Useful Post:
francab (17/07/2019), stephane (16/07/2019)
Vieux 16/07/2019, 23h08   #22
stephane
Avatar de stephane
bon alors je vient de regarder mes note je l ai ecrit a l orange 5
mais tu doigt pouvoir a l upa je jette un yeux
Vieux 16/07/2019, 23h17   #23
REDZONE31
Avatar de REDZONE31
Envoyé par stephane Voir le message
slt steph ok sinon tu peut me donner les pins de connexion du pic franchement je me bas pour trouver une solution alors que le pic et pris en charge dans le menu upa usb
Vieux 16/07/2019, 23h39   #24
stephane
Avatar de stephane
Salutation essaie ca A L UPA
OU CELUI-LA
C EST L ORANGE5 MODIFIER POUR UPA
Dernière modification par stephane ; 16/07/2019 à 23h55.
REDZONE31 (17/07/2019)
Vieux 17/07/2019, 00h07   #25
REDZONE31
Avatar de REDZONE31
ok sa marche je vais essayer l'autre type de montage
Vieux 17/07/2019, 00h24   #26
stephane
Avatar de stephane
OK essai le premier alors
Vieux 17/07/2019, 00h44   #27
REDZONE31
Avatar de REDZONE31
steph une question sur les deux pins P2 et P6 tu es sur de leur destination
Vieux 17/07/2019, 00h56   #28
REDZONE31
Avatar de REDZONE31
Vieux 17/07/2019, 07h43   #29
YUMBO
Avatar de YUMBO
Pouvoir de réputation: 23
YUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud of
C'est quoi ton problème ? Tu n'arrives pas à écrire du tout ou ce que tu écris ne correspond pas au fichier d'origine ?
C'est un PIC16F876 ou PIC 16F876A ,
YUMBO est déconnecté   Réponse avec citation
The Following User Says Thank You to YUMBO For This Useful Post:
Vieux 17/07/2019, 08h29   #30
REDZONE31
Avatar de REDZONE31
Envoyé par YUMBO Voir le message
slt exactement erreur écriture soit un probleme fichier ou du pic sa ne veux pas et ces un PIC 16F876A voila
Cherche Decodeur IAW 59f mindouza Vente, Achat, Echange 0 07/01/2019 09h03
Décodeur canal + francois Café du forum 103 04/01/2017 20h43
Cherche un decodeur autoradio fiat rayan38 Autoradio et Navigateur GPS 0 12/05/2015 12h27
Pin sur boitier decodeur Sly59 Transponder, code pin 4 23/10/2014 21h13
decodeur TMS 374 Mitch82 Immobilizer dumps/solutions 22 05/12/2012 15h13
Fuseau horaire GMT +1. Il est actuellement 01h25.
