Vieux 25/09/2021, 19h22   #16
chaoui05
Avatar de chaoui05
Pouvoir de réputation: 79
chaoui05 has a reputation beyond reputechaoui05 has a reputation beyond reputechaoui05 has a reputation beyond reputechaoui05 has a reputation beyond reputechaoui05 has a reputation beyond reputechaoui05 has a reputation beyond reputechaoui05 has a reputation beyond reputechaoui05 has a reputation beyond reputechaoui05 has a reputation beyond reputechaoui05 has a reputation beyond reputechaoui05 has a reputation beyond repute
Le calculateur est un échange standard.
Je n'est pas les données de l'écu original.
Seulement celui-ci actuel.
Pas de "Thanks" plus d'aide!
chaoui05 est déconnecté   Réponse avec citation
Vieux 25/09/2021, 19h23   #17
Pouvoir de réputation: 107
Ok je t envoi un test v1
chaoui05 (25/09/2021)
Vieux 25/09/2021, 19h26   #18
Tristan25
Avatar de Tristan25
Pouvoir de réputation: 26
Tristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant future
essaye sa
mp envoyé en mp
Type de fichier : rar a3 ok.rar (3,6 Ko, 1 affichages)
Tristan25 est connecté maintenant   Réponse avec citation
The Following User Says Thank You to Tristan25 For This Useful Post:
Vieux 25/09/2021, 19h32   #19
https://we.tl/t-rmQjFf0u41
Vieux 25/09/2021, 19h33   #20
chaoui05
Avatar de chaoui05
Merci les copains.
Je testerai demain du coup.
The Following 2 Users Say Thank You to chaoui05 For This Useful Post:
fils (25/09/2021), fruky (26/09/2021)
Vieux 25/09/2021, 19h37   #21
Tristan25
Avatar de Tristan25
Envoyé par chaoui05 Voir le message
Merci les copains.
[emoji106]
Vieux 26/09/2021, 10h32   #22
chaoui05
Avatar de chaoui05
Slt,
Bon bah, après test des solutions de Tristan25 et fils, toujours pareil.
Bon ,on va continuer à creuser.
Vieux 26/09/2021, 10h54   #23
Tristan25
Avatar de Tristan25
Slt,
J’ai deja eu se cas la sur un med17 de sirocco
C’etais du a un immo off fait auparavant et le client étais venu pour que je l’adapte
Il me semble avoir flasher l’ecu avec un sgo
Ton fichier ecu n’est pas reconnu en temps que appris ou immo off ou autre
Bon courage[emoji106]
chaoui05 (26/09/2021)
Vieux 26/09/2021, 11h32   #24
chaoui05
Avatar de chaoui05
Slt,
Voilà le décryptage des données immo du fichier extrait de l'écu à réception.
Pin et CS et qui étaient complètement différents.
Quant au statut , Inconnu !
Vieux 26/09/2021, 11h37   #25
Je pense Tristan a raison ils ont fait un off sur la flash ce qui indique l état inconnu. T es bon pour re flash un sgo à mon avis.
chaoui05 (26/09/2021), fruky (26/09/2021)
Vieux 26/09/2021, 11h56   #26
chaoui05
Avatar de chaoui05
Il me semble qu'AT propose des fichiers FRF ,si des utilisateurs l'ont déjà expérimenté,merci.
Vieux 26/09/2021, 12h27   #27
Tristan25
Avatar de Tristan25
Je pense que le frf ne fonctionnera pas le frf travail uniquement sur la partie map de la memoire flash et il n’est pas complet
Vieux 26/09/2021, 17h50   #28
Bird971
Avatar de Bird971
Bird971 is a jewel in the roughBird971 is a jewel in the roughBird971 is a jewel in the rough
Salut chaoui05,
Tu pourrais essayer de récupérer le flash et leeprom d'un autre compteur similaire au tiens et juste modifier les valeur via xprog. Comme j'ai fait sur mon compteur.
Je pense que c'est une solution simple (si pas de immo off sur la calculateur moteur)
J'ai bien un flash et eeprom associés mais c'est une compteur de facelift et l'autre compteur c'est un sans ordinateur de bord (pas d'écran au centre) si ça t'intéresse je peux te filer les dumps. Envoi moi un mp si tu le souhaite.
Tu vas y arriver ;)
Bird971 est déconnecté   Réponse avec citation
The Following User Says Thank You to Bird971 For This Useful Post:
Vieux 26/09/2021, 19h21   #29
chaoui05
Avatar de chaoui05
Envoyé par Bird971 Voir le message
Salut chaoui05,
Tu vas y arriver ;)
Slt,
Merci pour ta proposition mais je vais m'orienter vers une mise à jour de l'écu.
The Following User Says Thank You to chaoui05 For This Useful Post:
Bird971 (28/09/2021)
Vieux 29/09/2021, 21h31   #30
valentinriri
Avatar de valentinriri
valentinriri has a spectacular aura aboutvalentinriri has a spectacular aura aboutvalentinriri has a spectacular aura about
Salut chaoui05,
Tu vas y arriver ;)
Salut ,
Je complète la proposition de Brid971 avec les références que j'ai :
Flash + 24C32
  • 8P0920900P
  • 8P0920901J
  • 8P0920931E
  • 8P0920931S
  • 8P0920931F
  • 8P0920931T
  • 8P0920932D
  • 8P0920932E
  • 8P0920931G
  • 8P0920932Q
  • 8P0920981H
  • 8P0920982S
PS : Si tu a SAFE et que la voiture démarre ça veut dire que ton ECU est en OFF et que ta clé n'est pas reconnu par le DASH !
valentinriri est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to valentinriri For This Useful Post:
Bird971 (30/09/2021), chaoui05 (30/09/2021)
Ds150e données FAP inthemixx Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 20 26/02/2021 14h26
Donnees vehicules getstouss LEXIA, PP2000, DiagBox 2 06/06/2020 21h19
Base de données jo-11 Immobilizer dumps/solutions 2 17/10/2017 19h43
données antidemarages. Binbin Transponder, code pin 23 07/12/2016 04h22
Interprétation des données BSI looping8910 Electronique 11 06/04/2015 14h05
Fuseau horaire GMT +1. Il est actuellement 21h38.
