Vieux 08/02/2019, 21h28   #16
Drogo
V.I.P
Avatar de Drogo
Pouvoir de réputation: 90
Drogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond repute
Envoyé par magaratz Voir le message
Sur le même genre de voiture ?
c'est une E250CDI 4MATIC année 2011
ESPERAR E SABER ESPERAR É UMA GRANDE VIRTUDE
Drogo est déconnecté   Réponse avec citation
Vieux 08/02/2019, 21h33   #17
magaratz
Avatar de magaratz
Pouvoir de réputation: 27
magaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud of
Boite automatique ou manuel ?
---------- Post added at 21h33 ---------- Previous post was at 21h29 ----------
Turbo réguler électronique.controle câblage ou le module sur le turbo.merci.
on est tous egaux,cest la puissance qui nous separe.
magaratz est déconnecté   Réponse avec citation
Vieux 08/02/2019, 21h38   #18
Drogo
V.I.P
Avatar de Drogo
boite automatique
The Following User Says Thank You to Drogo For This Useful Post:
magaratz (17/03/2019)
Vieux 10/02/2019, 18h05   #19
sorcier16
Avatar de sorcier16
sorcier16 will become famous soon enoughsorcier16 will become famous soon enough
certain modéle propose en ligne sous das une adaptation de l actuateur de turbo !!!
sorcier16 est déconnecté   Réponse avec citation
Vieux 10/02/2019, 20h42   #20
RALPH
Avatar de RALPH
Pouvoir de réputation: 23
RALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud of
tu arrive a provoquer la panne, je voit que mesure paramètre sural pour voire ce qui se passe a ce moment
RALPH est déconnecté   Réponse avec citation
Vieux 23/02/2019, 19h56   #21
Drogo
V.I.P
Avatar de Drogo
problème résolu
Dernière modification par Drogo ; 01/03/2019 à 09h04.
The Following 2 Users Say Thank You to Drogo For This Useful Post:
guigui525 (26/02/2019), magaratz (17/03/2019)
Vieux 17/03/2019, 15h41   #22
malix83
Avatar de malix83
malix83 is on a distinguished road
Salut à tous
Recalibrage de la westgate electronic.
malix83 est déconnecté   Réponse avec citation
The Following User Says Thank You to malix83 For This Useful Post:
Vieux 17/03/2019, 19h16   #23
jphp
Avatar de jphp
Pouvoir de réputation: 250
Envoyé par Drogo Voir le message
problème résolu
@ tu vas peut etre nous dire comment tu as résolu ?? ca nous interresse !
bonne soirée
---------- Post added at 19h16 ---------- Previous post was at 19h11 ----------
Envoyé par malix83 Voir le message
Salut à tous
salut oui mais sur certains modeles le calibrage ne peux se faire que chez certains ateliers mm pas chez le concessionaire ! ex pour une audi A6 on a dut envoyer le turbo en Belgique pour calibrer !! eux seul avaient le materiel pour cette operation
Vieux 18/03/2019, 13h54   #24
aurelien
Avatar de aurelien
aurelien will become famous soon enoughaurelien will become famous soon enough
Envoyé par Amine-TE Voir le message
je reçois un ml250 a injection delphi,
j'ai le code défaut : P0248 MERCEDES-BENZ - Turbocharger/Supercharger Wastegate Solenoid 'B' Range/Performance
Turbo neuf et électrovanne neuf !!
une idée ?
salut amine desole de polluer ce post tu pourra supprimer le message par la suite sans probleme mais c est la seul solution que j ai trouver pour te contacter.
Je ne suis plus membre donateur pourtant mon dernier payement automatique date du 28 Fevrier.
je t ai envoyer 2 mails
je t ai poster un message sur ton mur
j ai ouvert un post mais rien y fait
peut tu stp resoudre mon probleme
merci a toi !
aurelien est déconnecté   Réponse avec citation
Vieux 21/03/2019, 08h36   #25
pmercury
Avatar de pmercury
pmercury will become famous soon enoughpmercury will become famous soon enough
c'est ta valve solenoid B qui marche pas ou pas au bon moment
ca resemble à ça, c'a envoi la dépression pour ouvrir ta valve de décompression turbo
teste la valve et teste si le courant arrive
pmercury est déconnecté   Réponse avec citation
Vieux 22/03/2021, 23h50   #26
mohcin2
Avatar de mohcin2
mohcin2 will become famous soon enough
Envoyé par drogo Voir le message
problème résolu
comment tu as pu resodre ton problem svp
mohcin2 est déconnecté   Réponse avec citation
PROBLEME UPA USB 1.2 vdd/vcc out of range khaledk Programmeur de chip 12 27/01/2016 16h56
réglage tige wastegate turbo géométrie variable tico Mécanique générale 31 10/09/2014 16h46
range rover drissdiag Immobilizer dumps/solutions 3 22/09/2013 16h42
Fuseau horaire GMT +1. Il est actuellement 13h07.
