Précédent   Tlemcen Car electronics > Outils & Diag > Diagnostic automobile > Opel-Vauxhall, Saab
Discussion fermée
Vieux 17/06/2015, 17h19   #1
electro_bordeaux1
Avatar de electro_bordeaux1
Pouvoir de réputation: 31
electro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud of
Par défaut P1631 et U2107 opel astra G
Bonjour a tous les membres j ai une opel astra G Y17DT qui demare pas et lorsque je debronche la batterie et je le rebronche ça demare et cale d apres l opcom j ai les defauts suivant
OP-COM 100219a - PC based diagnostic tool
OP-COM - KW2000 Communication Window> 2002 (2)|Astra-G|Engine|Y 17 DT
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0TGF692526xxxx
RepairShopCodeOrTesterSerialNumber: DELCOLVP13
ProgrammingDate: 20010815
systemSupplierECUHardwareNumber: DEL 0113386350
vehicleManufacturerECUHardwareNumber 97233370 DJ
systemSupplierECUSoftwareNumber: DLMD
systemSupplierECUSoftwareVersionNumber: 0002
exhaustRegulationOrTypeApprovalNumber: D01010
systemNameOrEngineType: Y17DTL
Identifier: 1321
CalibrationDate: STRCB0A
Total number of fault codes: 7
P0481 - Fan Relay 2 Signal Low / Open Circuit
(04) - Present
P0480 - Fan Relay 1 Signal Low / Open Circuit
(04) - Present
P1615 - <Unknown DTC>
(00) - Present
P1616 - <Unknown DTC>
(00) - Present
P0530 - A/C Refrigerant Pressure Sensor Circuit High Input
(01) - Present
U2107 - CAN-Bus no Communication with Body Control Module
(00) - Present
P1631 - Spill Valve Relay Voltage Low
(04) - Present
une piste a suivre et merci
l union fait la force
electro_bordeaux1 est déconnecté
Vieux 17/06/2015, 17h41   #2
Ecomouv
Avatar de Ecomouv
Pouvoir de réputation: 27
Ecomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud of
Salut, ton voyant moteur clignote ou est fixe ?
Tout ces defauts reviennent ?
Ouvre quand meme ton module de pompe pour controler les soudures . ca mange pas de pain . Bonne soirée
Ecomouv est déconnecté
Vieux 17/06/2015, 17h49   #3
electro_bordeaux1
j ai demonter le module les soudures sont ok
Vieux 17/06/2015, 18h08   #4
brahim chafa3
Avatar de brahim chafa3
brahim chafa3 has a spectacular aura aboutbrahim chafa3 has a spectacular aura aboutbrahim chafa3 has a spectacular aura about
ensuite effectuez une recherche sous la batterie vous trouverez qu'il ya des fille couper j'ai deja voir ce defaut
brahim chafa3 est déconnecté
Vieux 17/06/2015, 18h26   #5
MecaTech
super modérateur
Avatar de MecaTech
Pouvoir de réputation: 647
MecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond repute
Attention au calculateur de pompe à injection fixer à la pompe à injection!!
Voici un lien en détail sur le contrôle approfondi des soudures interne:
http://translate.google.fr/translate...mpenY17DTL.htm
[TUTO Op-Com] Paramétrage/Utilisation très complet!
http://www.tlemcen-electronic.com/fo...ad.php?t=39912
__________________________________________________ _____________
Dernière modification par MecaTech ; 17/06/2015 à 18h29.
MecaTech est déconnecté
Vieux 17/06/2015, 18h53   #6
jphp
Avatar de jphp
Pouvoir de réputation: 250
salut, que se passe t'il ds la console de bord quand tu met le contact, et que tu appui a fond sur l'accélérateur ? sans démarrer je veux dire juste contact on
jphp est déconnecté
Vieux 17/06/2015, 19h01   #7
electro_bordeaux1
le console de bord s allume normal
Vieux 17/06/2015, 19h51   #8
jphp
Avatar de jphp
bizarre, as tu un UCE sur l'aile avant gauche ? il est dessous les fusibles il faut ouvrir le boitier fusibles en 2
jphp est déconnecté
Vieux 17/06/2015, 20h03   #9
electro_bordeaux1
calculateur d injection au dessus du moteur
module de pompe au dessus de pompe
Vieux 17/06/2015, 20h29   #10
jphp
Avatar de jphp
Envoyé par electro_bordeaux1 Voir le message
bizarre je trouve que du bosch et toi c surement du denzo
donne moi le code moteur sltp
jphp est déconnecté
Vieux 17/06/2015, 20h31   #11
jphp
Avatar de jphp
Y17DTL je viens de voir, mais ca n'existe pas sur astra G recontrole sltp
jphp est déconnecté
Vieux 17/06/2015, 20h37   #12
MecaTech
super modérateur
Avatar de MecaTech
► Opel ASTRA-G Y17DT Année 2002, je suis ok ou pas " electro_bordeaux1 " ??
► Après 2002 tu as le moteur Z17DTL également!
Vieux 17/06/2015, 21h26   #13
electro_bordeaux1
c est justement ça Opel ASTRA-G Y17DT Année 2002
Vieux 17/06/2015, 21h34   #14
jphp
Avatar de jphp
on avance merci mon ami,
code P1631 boitier electronique de la pompe defectueux : cablage en court circuit sur le +, circuit ouvert
et U2107: boitier electronique multifonction panne du circuit bus de données can en panne ! cause probable : cablage
Dernière modification par jphp ; 17/06/2015 à 21h38.
jphp est déconnecté
Vieux 17/06/2015, 21h38   #15
electro_bordeaux1
merci jphp pour ton suivi donc module de pompe defectueux et les autres defauts P1615
P1616 U2107
Discussion fermée
Problème Opel Zafira 2.0 DTI Y20DTH: P1631 P1635 P0400 danyparis Mécanique générale 6 08/03/2014 01h15
Opel astra gtc plus de clé Liteonn Opel-Vauxhall, Saab 3 02/03/2014 12h15
Opel astra 1,7 memati Opel-Vauxhall, Saab 3 22/12/2011 17h44
Opel Astra H Mezz Airbag 0 26/04/2011 17h52
opel astra Auto16 Programmeur de chip 6 14/12/2009 22h30
Fuseau horaire GMT +1. Il est actuellement 00h26.
