Vieux 15/01/2014, 22h55   #16
Amine-TE
Fondateur
Avatar de Amine-TE
Pouvoir de réputation: 1330
Amine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond repute
Je crois que je vais essayer un calculateur que je ne trouve pas malheuresement, je vais chercher ...
Je ne donne pas d'aide en privé.
Amine-TE est déconnecté   Réponse avec citation
Vieux 16/01/2014, 00h12   #17
Meziane93
Avatar de Meziane93
Pouvoir de réputation: 29
Meziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud of
J en ai des calculos
Meziane93 est déconnecté   Réponse avec citation
Vieux 16/01/2014, 00h23   #18
MCNexo94
Avatar de MCNexo94
Pouvoir de réputation: 26
MCNexo94 is a splendid one to beholdMCNexo94 is a splendid one to beholdMCNexo94 is a splendid one to beholdMCNexo94 is a splendid one to beholdMCNexo94 is a splendid one to beholdMCNexo94 is a splendid one to beholdMCNexo94 is a splendid one to behold
si le code de la BSI était le mauvais saisie la BSI n'est pas HS il suffit de laisser le contact durant 15min et recommencer déjà fait ;).
MCNexo94 est déconnecté   Réponse avec citation
The Following User Says Thank You to MCNexo94 For This Useful Post:
land2a (16/01/2014)
Vieux 16/01/2014, 11h18   #19
HOUCINE2543
Avatar de HOUCINE2543
HOUCINE2543 has a spectacular aura aboutHOUCINE2543 has a spectacular aura about
salam amine, comment as tu resolu ton probleme de demarreur?
peut etre est ce lié?
je pense plus a un probleme de connexions bsi ou la fiche de l'antenne du neiman vu que tu as trifouillé sous le volant.
A voir
HOUCINE2543 est déconnecté   Réponse avec citation
Vieux 16/01/2014, 13h43   #20
Amine-TE
Fondateur
Avatar de Amine-TE
Re,
Démarreur c'étais la bsi qui été codé sur une boite auto.
The Following User Says Thank You to Amine-TE For This Useful Post:
VWPassat31 (30/09/2014)
Vieux 17/01/2014, 11h28   #21
HOUCINE2543
ca me rapelle le probleme sur les 1 eres megane 1.9dti qui avait le signal pmh perturbé par le demarreur!!
si la position "oui non" ne change que lorsque tu lance le demarreur, alors essaie de demarrer en la poussant,si ca demarre verifie les liaisons parasitées?
faut voir aussi si d'autres equipements ne parasite pas l'antenne transpondeur du neiman,
je pense que soit tu as un probleme de faux contact,soit un probleme de parasite.
Il y'a meme eu une histoire de voiture qui ne demarre pas a certains endroits a cause d'un relais telephone.
Bon courage les pannes vicieuses je les aimes quand je trouve les solutions!
Vieux 17/01/2014, 21h09   #22
jphp
Avatar de jphp
Pouvoir de réputation: 250
Envoyé par AMINE T-E Voir le message
Re,
ok ca c normal, mais en remettant l'ancien tu disait , pas de démarreur non plus ??
là je coince un peu !
tu as essayer un calculateur ?
perso je reste sur la connectique ABS, en plus tous ces codages , bsi etc
ca n'arrange rien, chaque calculateur changé amène ces problèmes en +
qui s'ajoute!!
tu peut faire un scan complet ?
post le .
Vieux 17/01/2014, 21h18   #23
Amine-TE
Fondateur
Avatar de Amine-TE
je suis entrain de chercher un nouveau calculateur pour tester !
Vieux 17/01/2014, 22h13   #24
baste59
Avatar de baste59
baste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to behold
si quoi comme calculateur
baste59 est déconnecté   Réponse avec citation
Vieux 17/01/2014, 22h28   #25
REDZONE31
Avatar de REDZONE31
Pouvoir de réputation: 82
REDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond repute
salam amine moi je pense que ton problème et interne au calculateur ou bsi .
soit EPROM ou les composant autours qui montre des signes de faiblesse
j'ai déjà eu un problème du même genre.
Allah se comportera avec toi comme tu te comportes avec autrui
REDZONE31 est déconnecté   Réponse avec citation
Vieux 17/01/2014, 23h09   #26
Kennfeld
Avatar de Kennfeld
Kennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud of
Re,
ok bien vu et comme le levier n'était ni sur park ni sur neutre car pas de levier du type monté tu pouvais toujours tenter de démarrer il avait pas l'autorisation de lancer le démarreur du coups !!! Logique !
Les masses du boitier moteur ont t'elles été testé ?
j'ai eut ca sur une 207 CC et le gars à l'entendre il n'avait fait aucune erreur
et en fait le client avait tenté de recharger sa batterie donc ....
en sortant le boitier il avait touché la coque du boitier contre le batterie plus donc il avait cramé toute les masses internes
Dernière modification par cedrsan ; 17/01/2014 à 23h37.
Kennfeld est déconnecté   Réponse avec citation
Vieux 17/01/2014, 23h35   #27
mecanodiag93
Avatar de mecanodiag93
Pouvoir de réputation: 32
mecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant future
salut tous le monde
vérifie la confuguration dans le bsi ( bva, bvm, berline break ext ,)
verifie la confuguration du calculo , bosch, continentale ,
verifie les masse moteur carosserie
a mon a vie , dump corrompu dans le bsi ou mauvaise configuration
jai des calculo vierge EDC17
envoi moi la ref je t'envoi un
bon courage
amine
ne fais pas à autrui ce que tu n'aimerais pas qu'on te fasse !!
mecanodiag93 est déconnecté   Réponse avec citation
The Following User Says Thank You to mecanodiag93 For This Useful Post:
Amine-TE (18/01/2014)
Vieux 18/01/2014, 00h33   #28
Amine-TE
Fondateur
Avatar de Amine-TE
@baste59
CONTINENTAL SID807
@amor89
Le dump de la bsi est recodé, si le dump de l'ecu est corrompu, ça peut êtres.
@Kennfeld
Le véhicule s'est arreté d'un seul coup.
@mecanodiag93
c'est trés gentil, mais c'est pas un EDC17 c'est plutot un SID807.
Vieux 18/01/2014, 08h57   #29
baste59
Avatar de baste59
j'ai un sid807 mais il faut trouves quelqu'un qu'il ramène en algerie
Vieux 18/01/2014, 09h58   #30
Shido
Avatar de Shido
Shido is on a distinguished road
Salam amine, quand tu as change la bsi, as tu remis la même référence, j ai eu un cas plus ou moins pareils sur un tepee de 2011 .
Shido est déconnecté   Réponse avec citation
Mode économie actif Xsara Mrpromega Peugeot, Citroën 4 13/06/2016 20h14
antidemarrage actif sur Puegoet 307 2001 CODE MOTEUR RHS skaner69 Peugeot, Citroën 8 03/08/2013 02h24
antidemarrage actif sur audi A3 ouioui83 Tableau de bord en général 6 04/06/2013 22h40
Anti demarrage actif sur laguna 2l rxe de 1996 greg08230 Immobilizer dumps/solutions 18 26/05/2013 21h08
Lancia kappa antidem actif nicocar Fiat, Alfaromeo, Lancia 6 08/12/2012 22h42
Fuseau horaire GMT +1. Il est actuellement 03h13.
