Go Back   Tlemcen Car electronics > Outils & Diag > Diagnostic automobile > Peugeot, Citroën
Register FAQ Community Donate New posts Search
Reply
Thread Tools
Old 09-06-2015, 08:40 PM   #1
rezki002
rezki002's Avatar
rezki002 will become famous soon enoughrezki002 will become famous soon enough
Default problème de combine 307
salut les amis de tl.
j'ai un problème avec ma voiture 307,Soudainement ce matin lorsque j'ai mis le contact je remarque que le voyant stop clignote et le voyant batterie fixe et jauge carburant et compte tour rien a fonctionnait.pour quoi je ne sais pas.
je suis arrivé tout les connecteurs mais tout va bien
rezki002 is offline   Reply With Quote
Old 09-09-2015, 09:39 PM   #2
abdel59100
abdel59100's Avatar
abdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond repute
Default
tu as fait un diag?
si oui tu as koi comme dtc
abdel59100 is offline   Reply With Quote
Old 09-09-2015, 09:55 PM   #3
tarik_electronic
tarik_electronic's Avatar
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Default
Bonsoir
A mon a vis combine hs
tarik_electronic is offline   Reply With Quote
Old 09-09-2015, 10:11 PM   #4
j-sky
j-sky's Avatar
Default
Ca ne sert a rien de remplacer des pièces sans faire un diag avec pp2000
Donne nous les défauts
Rappel des règles du forum
j-sky is offline   Reply With Quote
Old 09-12-2015, 06:04 PM   #5
elie
elie's Avatar
elie will become famous soon enough
Default
Salut ,si la voiture possede un aide au stationnement alors controle s'il n'y a pas d'eau dans le coffre .
elie is offline   Reply With Quote
Old 09-12-2015, 07:14 PM   #6
smart057
smart057's Avatar
smart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond repute
Default
Salut,les connecteurs BSI sont comment?
smart057 is offline   Reply With Quote
Reply
Bookmarks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
combine vdo 406 INVICTUS Compteur kilométrique 11 05-04-2015 11:44 AM
Diagbox probleme télécodage 208 combiné Yougataga Peugeot, Citroën 1 07-28-2014 10:03 PM
combiné 307 franck22 Peugeot, Citroën 15 06-08-2014 09:35 PM
probleme changement combiné 406 hdi kouider Tableau de bord en général 6 04-10-2013 07:38 PM
Combiné Audi A4 Formator Compteur kilométrique 5 12-12-2012 08:39 PM
