Vieux 17/04/2018, 22h47   #16
Bigorno91
Avatar de Bigorno91
Pouvoir de réputation: 30
Bigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant future
Slt
D'ailleur en general info temp manquante ou erronné en gle le ventilo tourne à fond...
Bigorno91 est déconnecté   Réponse avec citation
The Following User Says Thank You to Bigorno91 For This Useful Post:
rotax (17/04/2018)
Vieux 17/04/2018, 22h49   #17
rotax
Avatar de rotax
Pouvoir de réputation: 35
rotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond repute
c'est normal bigorno91 lol
rotax est déconnecté   Réponse avec citation
The Following User Says Thank You to rotax For This Useful Post:
Bigorno91 (17/04/2018)
Vieux 17/04/2018, 23h19   #18
Bigorno91
Avatar de Bigorno91
Envoyé par rotax Voir le message
Mais je sais parfaitement que c normale ce qui l'est moins c que ds son cas de figure il en parle pas .
The Following 3 Users Say Thank You to Bigorno91 For This Useful Post:
alinjadii (19/04/2018), rotax (17/04/2018), zenata (17/04/2018)
Vieux 17/04/2018, 23h22   #19
rotax
Avatar de rotax
on est d'accord :)
Bigorno91 (18/04/2018)
Vieux 17/04/2018, 23h36   #20
jphp
Avatar de jphp
Pouvoir de réputation: 250
il a surement un calorstat piloté là dessus , il a lut ce que la sonde du calorstat lui disait pas ce sa sonde de temp lui disait , il n'est pas sure que ses ventilo s'enclenche a fond !
ca va revenir !!
pour une mise a jour du calorstat piloté !! risque de casse moteur !!
zenata (17/04/2018)
Vieux 17/04/2018, 23h57   #21
rotax
Avatar de rotax
ca va revenir !!
non jphp la maj dont tu parle est valable que sur les 2.0l euro 6
jphp (18/04/2018)
Vieux 18/04/2018, 00h04   #22
jphp
Avatar de jphp
il lit au kts ! j'aimerai savoir si les ventilo s'affole aussi ! si oui c'etais bien sa sonde si non ca va revenir !!
aprés il y as sonde bleue, verte !!??
Dernière modification par jphp ; 18/04/2018 à 00h08.
Vieux 18/04/2018, 00h13   #23
rotax
Avatar de rotax
le mode dégrader du p2671 c'est alerte température d'eau au combiné !
sauf que p2671 correspond a une surintensité sur une ligne 5 volt qui sont:
capteur pression clim
capteur pression différentiel
ou bypass egr
rien en lien avec la température d'eau !!
---------- Post added at 12:10 AM ---------- Previous post was at 12:09 AM ----------
+ ventilo a fond ...
---------- Post added at 12:13 AM ---------- Previous post was at 12:10 AM ----------
salut joss21,
merci pour le retour.
sinon une petite question est-ce que tu avais essayé d'effacer le défaut avant de changer la sonde ?
si oui le défaut revenait à chaque coup ?
j'ai posez c'est question parce que je pense que ca va revenir ..
Vieux 18/04/2018, 00h14   #24
jphp
Avatar de jphp
pour moi aussi ca va revenir
rotax (18/04/2018)
Vieux 18/04/2018, 00h24   #25
rotax
Avatar de rotax
le truc ou il faut peu être faire attention, c'est que son outils de diag lui disais p2671 uniquement.
mais avec l'outils officiel a jour il y aurai peu être un Pcode liée a la température d'eau.
mais pour le coup j'en ai aucune idées ..
c'est vaste et très compliquer quand on doit prendre en compte les bug des outils de diag.
Vieux 18/04/2018, 00h37   #26
diagsam
Avatar de diagsam
diagsam is on a distinguished road
juste pour donner une autre aidée, moi j'avais le même problème, sur une 206 1.4 hdi, une fois je met le contact l’équille de température va directement au rouge, mais cette fois c’était problème de calculateur moteur, remplacement ecu et hop, tout va bien
diagsam est déconnecté   Réponse avec citation
Vieux 18/04/2018, 00h58   #27
rotax
Avatar de rotax
enfin ca n'explique pas pourquoi p2671
Vieux 18/04/2018, 23h36   #28
yann3
Avatar de yann3
Pouvoir de réputation: 74
alors je dit peut etre une betise,mais je me lance
le defaut est peut etre lié a la sonde pour les renseignement tempé lors de defap
bypass egr
pression differentiel fap
capteur clim'pour la mise en conso energetique,pour defap)
a creuser.
ce qui est sur,capteur tempé deffectueux= mode degradé,voir moteur qui tourne sur 3 pattes
Vieux 19/04/2018, 11h11   #29
joss21
Avatar de joss21
joss21 is a glorious beacon of lightjoss21 is a glorious beacon of lightjoss21 is a glorious beacon of lightjoss21 is a glorious beacon of lightjoss21 is a glorious beacon of lightjoss21 is a glorious beacon of light
salut joss21,
salut rotax
oui j'avais essayer a plusieurs reprise mais sans résultat, il revenait à chaque fois.
---------- Post added at 11h09 ---------- Previous post was at 11h06 ----------
Envoyé par Bigorno91 Voir le message
salut birgorno
effectivement je n'en ai pas parler car le ventilo ne tournais pas
bizarre...
---------- Post added at 11h11 ---------- Previous post was at 11h09 ----------
salut jphp
sonde verte
on verra s'il reviens...
un moteur sans rupteur c'est comme un vibromasseur sans pile,ça fait pas vibrer
joss21 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to joss21 For This Useful Post:
rotax (19/04/2018), zenata (19/04/2018)
Fse 3008 mahfoud lichani ABS, ESP, DSC 11 14/12/2023 19h28
Kilometrage 3008 jugurtha94 Compteur kilométrique 1 02/05/2017 18h00
3008 tony60 Peugeot, Citroën 4 11/11/2016 15h46
3008 kakou28 Compteur kilométrique 3 24/07/2016 14h33
fichier ori 3008 hdi sid 807 alexpert Fichiers d'origine, carto, dump, fullbackup 1 19/11/2013 21h40
Fuseau horaire GMT +1. Il est actuellement 05h39.
