Vieux 20/11/2019, 20h36   #1
zouaoui mohamed
Avatar de zouaoui mohamed
Pouvoir de réputation: 23
zouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to behold
Par défaut 207 1.4 e moteur et3j4
SLT A TOUS ,
j'ai une 207 1.4 16v essence moteur ET3J4 année 2007 qui me rend fou pas de communication avec ecu moteur ,abs , direction assistée et bien sur elle ne démarre pas alimentation abs ok alimentation ecu moteur ok bsm changer , abs changer toujour pareil de l'aide svp merci.
zouaoui mohamed est déconnecté   Réponse avec citation
Vieux 20/11/2019, 20h43   #2
barthdu22
Avatar de barthdu22
barthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud of
Salut debranche la batterie et controle que tu a bien 60 Ohms entre la prise 6 et 14 de la prise diag
barthdu22 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to barthdu22 For This Useful Post:
zenata (20/11/2019), zouaoui mohamed (20/11/2019)
Vieux 20/11/2019, 20h52   #3
fayssal2017
Avatar de fayssal2017
fayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond repute
Envoyé par zouaoui mohamed Voir le message
SLT A TOUS ,
T'as changé l'ECU?
Est ce que tu communique avec l'ABS après son remplacement?
T'as contrôlé tous les fusibles et relais?
T'sa contrôlé le CAN?
Post ici les défauts de tous les calculateurs,,
Il y a une nette différence entre ancienneté et expérience
fayssal2017 est déconnecté   Réponse avec citation
The Following User Says Thank You to fayssal2017 For This Useful Post:
zouaoui mohamed (21/11/2019)
Vieux 20/11/2019, 20h56   #4
zouaoui mohamed
bien exactement 59.8 ohm
Vieux 20/11/2019, 21h17   #5
zouaoui mohamed
Envoyé par fayssal2017 Voir le message
T'as changé l'ECU?
merci pour ta réponse, ecu changer oui
pas de communication après changement abs
tous les fusible vérifier oui bien sur
can ok
Vieux 20/11/2019, 21h35   #6
zouaoui mohamed
VOILA LES IMAGES
Type de fichier : jpg 20191120_210739.jpg (96,4 Ko, 22 affichages)
Vieux 20/11/2019, 21h41   #7
zouaoui mohamed
VOILA LES IMAGES
ESOLE
---------- Post added at 21h39 ---------- Previous post was at 21h36 ----------
ESOLE
---------- Post added at 21h41 ---------- Previous post was at 21h39 ----------
ESOLE
Vieux 20/11/2019, 21h45   #8
zenata
Avatar de zenata
Pouvoir de réputation: 174
Salam
C'est quoi les 5 dtc dans bsi ?
Pilouf (21/11/2019), zouaoui mohamed (21/11/2019)
Vieux 20/11/2019, 22h11   #9
fayssal2017
Arrow
Si t'as changé tous les calculateurs alors il faut recontrôler le câblage du CAN entre le BSI et les autres calculateurs (coupure, pin endommagé, corrosion...)
Vieux 20/11/2019, 22h45   #10
dreamland
Avatar de dreamland
Pouvoir de réputation: 45
Hello
Débranche le connecteur 3 voies qui alimente la DA en CAN , le connecteur est fixé sur le coffre a batterie a l'arrière pas trés loin du maitre cylindre de frein
The Following User Says Thank You to dreamland For This Useful Post:
Vieux 21/11/2019, 08h27   #11
zouaoui mohamed
Par défaut re
merci a tous pour votre aide voila l'image des erreures sur bsi
Type de fichier : jpg 20191120_210754.jpg (92,9 Ko, 16 affichages)
Vieux 21/11/2019, 09h28   #12
bino78
Avatar de bino78
Pouvoir de réputation: 9
bino78 has a spectacular aura aboutbino78 has a spectacular aura aboutbino78 has a spectacular aura about
Salam mohamed verifie les faisceaux calculateurs et bsi et les pins si il n' yen a pas un de tordu.
bino78 est déconnecté   Réponse avec citation
Vieux 21/11/2019, 18h37   #13
barthdu22
Avatar de barthdu22
Salut, si tu as bien 60 ohms c'est que ton reseau CAN I/S n'est pas coupé ni en court circuit. Met le contact et controle entre la masse et la pin 6 de la prise diag puis entre la masse et la pin 14 de la prise diag et tu doit avoir environ 2.4 et 2.6 volts.
Apres ces controles fait comme a dit Dreamland, dbranche le calculateur direction assisté et essai de communiquer avec l'abs et l'ecu.
Si tu ne communique toujours pas rebranche la DA et debranche l'ABS mais tu doit faire 2 shunts sur le connecteur abs (je ne me rappel plus des pins)
Boitier moteur de sprinter 312D (1122cv) sur 310 D ( 102cv ) meme moteur 5cyl TD fils schémas de câblage, documentation 20 04/08/2020 19h31
esque le fissaux moteur dune 406 avec un moteur hdi 2.2 136 et le meme qun faissaux p mourad44 Automobile en général 5 10/06/2019 21h51
Remplacer moteur 2lHDI 110cv par moteur 2l HDI 90cv zingilingiling Peugeot, Citroën 23 04/12/2018 00h16
Calculateur Moteur ABT pour moteur VAG 1.8L turbo Gerux Vente, Achat, Echange 0 19/09/2014 07h19
Fuseau horaire GMT +1. Il est actuellement 00h19.
