Vieux 19/01/2019, 11h43   #16
stephane
Avatar de stephane
Pouvoir de réputation: 120
stephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond repute
Salutations
Ont à essayé avec yves une fois le hfm vierge tu as besoins ou du pin ou de l isk pour recoder le hfm ,vue qu'il ne pouvais pas l avoir .....case RENAULT ..
stephane est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to stephane For This Useful Post:
chipshop (19/01/2019), oran13 (19/01/2019), techtronic1 (19/01/2019), yvespapou (19/01/2019)
Vieux 19/01/2019, 12h19   #17
oran13
Avatar de oran13
oran13 is a splendid one to beholdoran13 is a splendid one to beholdoran13 is a splendid one to beholdoran13 is a splendid one to beholdoran13 is a splendid one to beholdoran13 is a splendid one to beholdoran13 is a splendid one to behold
Salut Stephane, je m en doutais mon collègue m avait prévenu qu il était pas sure que Ret le fasse malgré que l option soit dispo dans Ret. ( du moins sans l isk).
Il me semble que l avdi le fait sauf erreur de ma part?
oran13 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to oran13 For This Useful Post:
stephane (19/01/2019), yvespapou (19/01/2019)
Vieux 19/01/2019, 12h21   #18
yvespapou
Avatar de yvespapou
Pouvoir de réputation: 37
yvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond repute
Bon de tout façon une fois vierge impossible de faire un apprentissage car il demande le code isk ou pin donc si vous avez pas le lecteur donc je vois pas l intérêt de cette option bon pour lire le lecteur par pinout le schéma je l'ai pas ecu tool montre le pinout juste pour le lecteur double fiche de tout façon j'ai fait un vierge donc maintenant c'est foutu merci à tous pour votre aide
---------- Post added at 12:20 PM ---------- Previous post was at 12:19 PM ----------
Moi j ai un lecteur 1 fiche je n ai pas le pinout
---------- Post added at 12:21 PM ---------- Previous post was at 12:20 PM ----------
Je n ai pas le pinout
yvespapou est déconnecté   Réponse avec citation
The Following User Says Thank You to yvespapou For This Useful Post:
Vieux 19/01/2019, 12h23   #19
stephane
Avatar de stephane
A planché .....il doigt y avoir un moyen de récupéré ailleurs que dans le hfm
A suivre .....
The Following 2 Users Say Thank You to stephane For This Useful Post:
oran13 (19/01/2019), yvespapou (19/01/2019)
Vieux 19/01/2019, 12h27   #20
tico
Avatar de tico
Pouvoir de réputation: 27
tico has much to be proud oftico has much to be proud oftico has much to be proud oftico has much to be proud oftico has much to be proud oftico has much to be proud oftico has much to be proud oftico has much to be proud oftico has much to be proud oftico has much to be proud of
Suffit de le demander mon ami =)
---------- Post added at 12:27 PM ---------- Previous post was at 12:25 PM ----------
J'ai un fichier d'un hfm 1 broche aussi si tu veux essayer
tico est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to tico For This Useful Post:
chipshop (19/01/2019), oran13 (19/01/2019), Tidus97 (19/01/2019), yvespapou (19/01/2019)
Vieux 19/01/2019, 12h56   #21
tico
Avatar de tico
Je prépare un petit dossier en téléchargement
---------- Post added at 12h56 ---------- Previous post was at 12h51 ----------
http://dl.free.fr/jfZAyb5Z9
je t'envoi en mp le pass
The Following 2 Users Say Thank You to tico For This Useful Post:
klif26 (19/01/2019), yvespapou (19/01/2019)
Vieux 19/01/2019, 13h27   #22
oran13
Avatar de oran13
@tico : peux tu me donner plus de détail sur ton fichier stp c est un dump de hfm c est ça? Vierge ou déjà codé? Si il est déjà codé ça pourrai permettre à Yves de savoir si avec ton dump Ret arrive à récupérer l isk .. bien entendu le vehicule ne démarrera pas mais juste pour savoir si le problème vient du hfm ?
@steph: Yves a les cartes d origine c est pas plus simple pour Renault de récupéré l isk ... depuis la carte? Je sais pas si c est faisable
The Following User Says Thank You to oran13 For This Useful Post:
Vieux 19/01/2019, 13h34   #23
tico
Avatar de tico
Oui déjà codé.
Pour moi se serait de mettre dessus de refaire vierge et de réapprend ses cartes ori
Vieux 19/01/2019, 13h36   #24
oran13
Avatar de oran13
Il a déjà essayé ce matin, le hfm est vierge mais impossible de le réapprendre avec Ret car il n à pas le pin isk ...
Vieux 19/01/2019, 13h56   #25
yvespapou
Avatar de yvespapou
Merci tico super sympa de ta part pour ce partage il faut voir car après le vierge ecu tool te demande isk ou le pin
tico (19/01/2019)
Vieux 19/01/2019, 14h15   #26
Tidus97
Avatar de Tidus97
Pouvoir de réputation: 36
Tidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond repute
Slt Yves,
c'est quoi comme ecu que t'as sur ta clio 4? Peut être un moyen de récupérer à partir de l'ecu comme ceux des dcm/ddcr et sid. Une idée.
Sinon vierge ecu+données de Tico+nouvelles cartes.
Tidus97 est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to Tidus97 For This Useful Post:
oran13 (19/01/2019), tico (19/01/2019), yvespapou (19/01/2019)
Vieux 19/01/2019, 14h30   #27
tico
Avatar de tico
il a une carte original de la clio il me semble!? donc c'est ok normalement!?
-mettre les données que je t'ai mis dans le hfm
-vierginisé le hfm
-learn hfm avec la carte original!!?
Sinon comme dis notre ami Tidus!! j'ai pas mieux moi ;)
oran13 (19/01/2019), skeuf (19/01/2019), Tidus97 (19/01/2019), yvespapou (19/01/2019)
Vieux 19/01/2019, 14h35   #28
skeuf
Avatar de skeuf
Pouvoir de réputation: 72
Sa n’avancera pas ton problème
Mais
Tu peut nous donner l’année de la clio stp yves
Si c’est une 2015 possible d’avoir le mois ?
skeuf est connecté maintenant   Réponse avec citation
The Following 3 Users Say Thank You to skeuf For This Useful Post:
tico (19/01/2019), Tidus97 (19/01/2019), yvespapou (19/01/2019)
Vieux 19/01/2019, 14h41   #29
oran13
Avatar de oran13
@tidus: très bonne idée que tu proposes vierge écu+ donnée de Tico pour hfm + vierge dae et recordage avec renolink + verrou colonne, sinon clone de tous les elements de ma clio si celle à Yves est la même.
@tico: même avec la carte originale il faut le pin isk
The Following 4 Users Say Thank You to oran13 For This Useful Post:
skeuf (19/01/2019), tico (19/01/2019), Tidus97 (19/01/2019), yvespapou (19/01/2019)
Vieux 19/01/2019, 14h47   #30
tico
Avatar de tico
dans ce cas learn hfm est inutile si il peux pas le codé via la carte.... lol
---------- Post added at 14h47 ---------- Previous post was at 14h43 ----------
il y bien quelqu'un içi qui boss chez renault pour avoir le pin
The Following 3 Users Say Thank You to tico For This Useful Post:
Carte zoe lecteur carte clio 4 skeuf Vente, Achat, Echange 1 12/11/2018 18h24
Carte Clio 4 Thomas_59 Programmeur de clé 5 03/04/2018 14h13
carte clio IV meca Vente, Achat, Echange 0 09/12/2017 21h09
carte clio iv carto Vente, Achat, Echange 1 16/08/2017 17h48
carte clio 4 momo78100 Vente, Achat, Echange 2 24/03/2017 01h20
Fuseau horaire GMT +1. Il est actuellement 02h20.
