Précédent   Tlemcen Car electronics > Outils & Diag > Outils de diagnostique > Renault clip, DDT2000, Nissan consult
Vieux 19/03/2019, 14h12   #46
petru2a
Avatar de petru2a
petru2a is a splendid one to beholdpetru2a is a splendid one to beholdpetru2a is a splendid one to beholdpetru2a is a splendid one to beholdpetru2a is a splendid one to beholdpetru2a is a splendid one to beholdpetru2a is a splendid one to behold
Vous croyez
petru2a est déconnecté   Réponse avec citation
Vieux 19/03/2019, 15h07   #47
progdebutant
Avatar de progdebutant
progdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond repute
Au diag au niveau de l'uch tout est normal ?
progdebutant est déconnecté   Réponse avec citation
The Following User Says Thank You to progdebutant For This Useful Post:
petru2a (19/03/2019)
Vieux 19/03/2019, 15h23   #48
petru2a
Avatar de petru2a
Envoyé par progdebutant Voir le message
Je ne c pas , j ai pas navigué dedans :-)
Peux tu me dire où regarder ?
Vieux 19/03/2019, 19h27   #49
petru2a
Avatar de petru2a
Re à tous
Alors j ai branché la CLip j ai été dans uch , et apparemment rien de spécial
Appart 1 seul carte apprise
Si quelqu’un peut m aider car je suis perdu
Vieux 19/03/2019, 20h12   #50
abdel93
Avatar de abdel93
Pouvoir de réputation: 31
abdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond repute
franchement la appar quelqu'un qui a eu le même soucie que toi ,je pense que ca va être dur de t'aider plus que ca
un petit thank ca fait pas de mal
abdel93 est déconnecté   Réponse avec citation
The Following User Says Thank You to abdel93 For This Useful Post:
Vieux 19/03/2019, 20h32   #51
petru2a
Avatar de petru2a
Envoyé par abdel93 Voir le message
Oh non me dis pas ça :-(
Vieux 19/03/2019, 21h11   #52
progdebutant
salut l'ami
est ce que la voiture démarre bien avec la carte d'origine ?
en ce moment elle roule ou immobilisé depuis un petit moment ?
Vieux 19/03/2019, 22h20   #53
petru2a
Avatar de petru2a
salut l'ami
Elle roule bien , juste des fois voir souvent carte non détectée
C pour ça que je veux faire une autre carte
Pour ne pas être embêté :-)
- j ai testé aussi avant avec FVDI avec contact mis , veilleuse ou pas toujours le même message erreur
Vieux 19/03/2019, 22h25   #54
Pouvoir de réputation: 277
A priori tu habite en Corse peu être quelq'un à écutool près de chez toi qui sais en 5 minutes chrono je suis sûre c'est fais..
Vieux 19/03/2019, 22h28   #55
petru2a
Avatar de petru2a
Je connais personne qui a ecutool
The Following User Says Thank You to petru2a For This Useful Post:
akasa67 (19/03/2019)
Vieux 19/03/2019, 22h29   #56
La misere et renolink..
Vieux 19/03/2019, 22h40   #57
petru2a
Avatar de petru2a
Renolink aparament ça me met erreur aussi
---------- Post added at 22h40 ---------- Previous post was at 22h38 ----------
Voilà l erreur que j ai avec renolink
7F3B12 sub fonction not supported
Vieux 19/03/2019, 22h44   #58
progdebutant
même si tu arrives à communiquer avec l'uch, revérifie chaque connections minutieusement.
aucun défaut ne remonte?
---------- Post added at 22h44 ---------- Previous post was at 22h43 ----------
si possible donne la main avec teamviewer pour essayer avec renolink
Vieux 19/03/2019, 22h50   #59
petru2a
Avatar de petru2a
Je n avais aucun défaut dans l uch
Appart pile à changer ( de la carte )
Vieux 20/03/2019, 09h24   #60
petru2a
Avatar de petru2a
Salut à tous :-)
Ça y es enfin :-)
- alors j ai installé FVDI sur un autre PC , et là miracle
J ai pu enfin effectué l apprentissage de ma carte ENFIN
En 2 min ,
Alors pourquoi ça ne fonctionnait pas sur mon autre pc ça je ne c pas , ou peut être d avoir navigué avec la clip je ne c pas du tout .
En tout cas , merci à tous de m avoir aidé conseiller :-)
Si ça peux aider quelqu’un, tant mieux .
PS: si quelqu’un a une bonne adresse pour carte démarrage CLIO 3 main libre , je suis preneur
Car la carte que j ai faite , tout marché centralisation etc...
Mais obligé de la mettre dans le lecteur de carte .
The Following 2 Users Say Thank You to petru2a For This Useful Post:
abdel93 (20/03/2019), akasa67 (20/03/2019)
carte non reconnu apprentissage Renault can clip uch occupe micheldpt programmation & synchronisation de clé 21 19/11/2016 08h19
code BSI? pour apprentissage cle 307 mysterauto Transponder, code pin 4 04/12/2015 21h56
Problème apprentissage clé avec Can Clip v140 r1lef programmation & synchronisation de clé 8 15/08/2014 14h30
code d acces pour apprentissage cle electro_bordeaux1 programmation & synchronisation de clé 17 06/01/2014 21h53
probleme pour apprentissage cle switt programmation & synchronisation de clé 14 08/03/2012 05h58
Fuseau horaire GMT +1. Il est actuellement 01h01.
