Discussion fermée
Vieux 16/07/2025, 19h47   #1
karera 1
Avatar de karera 1
Par défaut edc17c60 psa
bonjour a tous j'aurais besoin de mettre en immo off mon ecu edc17c60 psa 208 faut faire sur flash ou eprom svp je joint les 2 fichier merci
Type de fichier : rar TC1793_10SW016159-20250716-190159 FLASH.rar (1,55 Mo, 7 affichages)
Type de fichier : rar TC1793_eeprom-20250716-185628.rar (11,8 Ko, 9 affichages)
karera 1 est déconnecté
Vieux 16/07/2025, 20h06   #2
kariminho
Avatar de kariminho
Pouvoir de réputation: 3
kariminho will become famous soon enough
J'ai tenté un immo off, teste le et fais moi ton retour si cela fonctionne.
Cordialement!
Type de fichier : rar TC1793_10SW016159-20250716-190159 FLASH_immo_off.rar (1,54 Mo, 2 affichages)
kariminho est déconnecté
The Following User Says Thank You to kariminho For This Useful Post:
karera 1 (16/07/2025)
Vieux 16/07/2025, 20h10   #3
karera 1
Avatar de karera 1
merci kariminho mais il me faut methode deja tester vehicule etant loin merci pour ton aide
Vieux 16/07/2025, 20h12   #4
a3pughjolu
Avatar de a3pughjolu
Pouvoir de réputation: 23
a3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud of
OFF sur Flash + eeprom
Aider et etre Aidé Pas de Thanks Pas de réputation Plus d'aide
Dernière modification par a3pughjolu ; 16/07/2025 à 20h16.
a3pughjolu est déconnecté
Vieux 16/07/2025, 20h16   #5
Fastdiag
Avatar de Fastdiag
Fastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond repute
Slt
Off sur eeprom. J ai pas mon pc sur moi. Demain si ca peut attendre.
Cordialement
---------- Post added at 18h16 ---------- Previous post was at 18h14 ----------
Pourquoi veux tu faire un off ?
Tu veux pas plutôt adapter le pin ?
Cordialement
Il ne faut pas perdre son temps à avancer des arguments de bonne foi face à des gens de mauvaise foi
Fastdiag est déconnecté
The Following User Says Thank You to Fastdiag For This Useful Post:
Vieux 16/07/2025, 20h25   #6
a3pughjolu
Voila flash+Eeprom
Pass dans ta boite
Type de fichier : txt EDC17C60.txt (73 octets, 0 affichages)
The Following 2 Users Say Thank You to a3pughjolu For This Useful Post:
karera 1 (16/07/2025), mawoussiboris (16/07/2025)
Vieux 16/07/2025, 20h49   #7
mawoussiboris
Avatar de mawoussiboris
Envoyé par a3pughjolu Voir le message
Voila flash+Eeprom
Pass dans ta boite
Salut, sur eeprom c'est + stable, parfois sur flash ca fait passer en mode économie, comme chaque cas peut etre différent il peut essayer les 2 mais je conseille eeprom seulement et si l'intéressé veut tester, j'ai un algo dans la flash qui devrait marcher sans créer mode économie ni rien et sans toucher la flash.
J'avoue j'ai oublié de rectifier dans RobinX
---------- Post added at 18h49 ---------- Previous post was at 18h46 ----------
Envoyé par mawoussiboris Voir le message
Erratum, sans toucher l'eeprom
mawoussiboris est déconnecté
The Following 5 Users Say Thank You to mawoussiboris For This Useful Post:
a3pughjolu (16/07/2025), dalco (03/08/2025), fufounet (20/07/2025), karera 1 (16/07/2025)
Vieux 16/07/2025, 20h57   #8
a3pughjolu
On avance On Avance je me suis permis..
klif26 (16/07/2025), mawoussiboris (16/07/2025)
Vieux 16/07/2025, 21h02   #9
mawoussiboris
No problème j'ai vu dans les logs [emoji6] à 20h17, si ça peut l'aider, et puis c'est un membre actif. Je l'aurais fait de toute façon
Sent from my 23117RA68G using Tapatalk
The Following User Says Thank You to mawoussiboris For This Useful Post:
klif26 (16/07/2025)
Vieux 17/07/2025, 20h06   #10
jean-marc 10
Avatar de jean-marc 10
jean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud of
Salut voila pour toi eprom off cheksum a corriger !
Pass en mp !
Type de fichier : rar TC1793_eeprom-20250716-185628.bin(_IMMO_OFF).rar (11,8 Ko, 1 affichages)
jean-marc 10 est déconnecté
The Following 2 Users Say Thank You to jean-marc 10 For This Useful Post:
karera 1 (20/07/2025), reda75 (18/07/2025)
Vieux 20/07/2025, 16h06   #11
karera 1
Avatar de karera 1
salut a tous merci pour vos aides j'ai demarrer le vehicule tous et ok seulement fait sur eprom avec prog de reda demarre et roule impeccable sujet merci a tous
The Following 2 Users Say Thank You to karera 1 For This Useful Post:
dalco (03/08/2025), MecaTech (20/07/2025)
Discussion fermée
Edc17c60 reprog-auto94 Electronique 3 19/12/2023 13h54
Edc17c60 Tof02770 Réparation & Programmation 17 12/05/2019 09h39
Dfp off edc17c60 Tof02770 Immobilizer dumps/solutions 0 02/05/2019 10h40
Edc17c60 dfp off Tof02770 Réparation & Programmation 0 01/05/2019 16h32
Edc17c60 psa scorpion593 Réparation & Programmation 4 14/04/2019 14h32
Fuseau horaire GMT +1. Il est actuellement 01h16.
