Vieux 18/11/2025, 11h46   #1
fufounet
Avatar de fufounet
Pouvoir de réputation: 41
Par défaut ref sam arriere ml w164 320 CDI 2.9 CDI V6 24V 224 cv Boîte auto
je recherche les ou la ref possible pour un sam arriere pour ce ml
il y a certains problemes electriques insolubles .
je ne suis vraiment pas sur de la reference montée dessus
je joint le vin
Code moteur :642940
Code de boîte :722.902
1ère immat. :02/11/2005
VIN :WDC1641221A035360
merci !
Vieux 18/11/2025, 12h18   #2
matt978
Avatar de matt978
matt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud of
Envoyé par fufounet Voir le message
je joint le vin
Code moteur :642940
merci !
salut avec ton VIN (que tu n'aurais pas du afficher sur ton post mais uniquement en privé)
j'ai trouvé ca:
A 164 440 43 01 CONTROL UNIT, SAM 200 SIGNAL ACQUISITION AND ACTUATION MODULE, REAR 001 Replaced by: A 164 900 51 01 PART MUST BE CHECKED AFTER INSTALLATION FOR CURRENT FLASHWARE
A 164 900 69 00 CONTROL UNIT, COMPLETE 200 SIGNAL ACQUISITION AND ACTUATION MODULE, REAR 001 Replaced by: A 164 440 43 01 PART MUST BE CHECKED AFTER INSTALLATION FOR CURRENT FLASHWARE
A 164 900 45 00 ELECTRICAL CENTER 200 SIGNAL ACQUISITION AND ACTUATION MODULE, REAR 001 Replaced by: A 164 900 69 00 PART MUST BE CHECKED AFTER INSTALLATION FOR CURRENT FLASHWARE
A 164 440 32 01 CONTROL UNIT, SAM 200 SIGNAL ACQUISITION AND ACTUATION MODULE, REAR 001 Replaced by: A 164 900 45 00 PART MUST BE CHECKED AFTER INSTALLATION FOR CURRENT FLASHWARE
A 164 540 19 01 CONTROL UNIT, SAM 200 SIGNAL ACQUISITION AND ACTUATION MODULE, REAR 001 Replaced by: A 164 440 32 01 PART MUST BE CHECKED AFTER INSTALLATION FOR CURRENT FLASHWARE
A 164 540 98 62 CONTROL UNIT, SAM 200 SIGNAL ACQUISITION AND ACTUATION MODULE, REAR 001 Replaced by: A 164 540 19 01 PART MUST BE CHECKED AFTER INSTALLATION FOR CURRENT FLASHWARE
je ne sais pas si ca te conviendra??
---------- Post added at 12h18 ---------- Previous post was at 12h15 ----------
pareil pour info si tu cherches la date de fabrication de ton auto c'est : le 13.08.2005
matt978 est déconnecté   Réponse avec citation
The Following User Says Thank You to matt978 For This Useful Post:
fufounet (18/11/2025)
Vieux 18/11/2025, 12h37   #3
fufounet
Avatar de fufounet
salut et merci
si un modo passe par la pour me cacher le vin c est cool
---------- Post added at 10h37 ---------- Previous post was at 10h35 ----------
salut et merci
donc j ai pas la bonne ref de sam arriere
j ai A 164 540 77 45
Recherche Sam Arriere W164 sergyu2006 Vente, Achat, Echange 0 03/07/2023 18h55
Probleme de marche arriere boite auto bilbil69 VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 1 03/08/2018 08h37
besoin flash ecu ssangyoung boite auto a boite manuelle aloula17 Fichiers d'origine, carto, dump, fullbackup 0 02/04/2016 00h43
A4 cab boite auto plus de marche arriere legrek Boite de vitesse 7 10/08/2015 10h37
calculateur audi edc17 boite meca sur boite auto 2longue Réparation & Programmation 2 13/01/2015 09h08
Fuseau horaire GMT +1. Il est actuellement 17h19.
