Vieux 22/10/2014, 17h58   #1
carspeed
Avatar de carspeed
carspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to behold
Par défaut Code Pin 407
bonjour a tous les membres
j'ai besoin du code pin 407
Voici la lecture du bsi siemens 95160
merci d'avance
Type de fichier : rar bsi 407.rar (4,2 Ko, 24 affichages)
carspeed est déconnecté   Réponse avec citation
Vieux 22/10/2014, 18h09   #2
foulques
Avatar de foulques
code pin 8RH6
The Following User Says Thank You to foulques For This Useful Post:
carspeed (22/10/2014)
Vieux 22/10/2014, 18h12   #3
zidane autodiag
Avatar de zidane autodiag
zidane autodiag is a jewel in the roughzidane autodiag is a jewel in the roughzidane autodiag is a jewel in the roughzidane autodiag is a jewel in the rough
code pin : 8RH6
Dtc, Egr, Dpf,Throttle, Flaps, Lambda, Hotstart, AdBlue, Evap, Nox, Speed limiter
Skype : soufi217
zidane autodiag est déconnecté   Réponse avec citation
The Following User Says Thank You to zidane autodiag For This Useful Post:
Vieux 22/10/2014, 18h15   #4
carspeed
Avatar de carspeed
Merci mes amis
The Following User Says Thank You to carspeed For This Useful Post:
newcar (22/11/2014)
Vieux 22/10/2014, 20h13   #5
aza
Avatar de aza
aza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud of
......mais ce dump bsi 407 et code pin correspondent ....a un bsi valeo type 1 avec eeprom 25C128 et non au bsi seimens 95160.....salutation les amis
aza est déconnecté   Réponse avec citation
Vieux 23/10/2014, 10h30   #6
carspeed
Avatar de carspeed
Envoyé par aza Voir le message
Oui exactement bsi valeo avec eeprom 25C128 un erreur de mon ami qui ma donne le information incorrecte
J'ai aurait un tuto pour extrait le pin code de ce dump a partir d'un editor hex
Est merci d'avance
newcar (22/11/2014)
Vieux 23/10/2014, 11h42   #7
carspeed
Avatar de carspeed
Un ami m'a dit
dans votre cas PIN enregistré dans h000006208:C7ADB7C9 xor
FFFFFFFF =38524836,
Donc 38524836 hex = 8RH6 ASCII
quelqu un peut expliquer
newcar (22/11/2014)
Vieux 23/10/2014, 13h27   #8
volavka
Avatar de volavka
Pouvoir de réputation: 23
volavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to behold
super leecher, cet ami est ici aussi
Br. Mouad Amenchar
Dernière modification par volavka ; 23/10/2014 à 14h44.
volavka est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to volavka For This Useful Post:
carspeed (23/10/2014), diagnosis29 (23/10/2014), diagprog (23/10/2014), newcar (22/11/2014)
Vieux 23/10/2014, 16h13   #9
carspeed
Avatar de carspeed
Envoyé par volavka Voir le message
Slt mon ami volavka est merci beaucoup
Pas facile à apprendre, mais facile à apprendre ce que j'ai appris;
pour apprendre à l'autre.
voila ton effort
Merci a tous
Type de fichier : jpg 8RH6.jpg (95,1 Ko, 23 affichages)
newcar (22/11/2014)
Fuseau horaire GMT +1. Il est actuellement 14h38.
