Vieux 26/04/2023, 15h52   #1
chafi
Avatar de chafi
chafi is a jewel in the roughchafi is a jewel in the roughchafi is a jewel in the rough
Par défaut Peugeot Partner b9 bsi virgin 95128
s'il vous plaît
quelqu'un peut-il rendre ce fichier vierge
96 640 587 8001
BSI04EV K01-00 090708
Merci.
Type de fichier : zip BSI PEUGEOT PATRNER 2009 _Johnson control _95128 ORG.zip (6,6 Ko, 17 affichages)
"Failure is the condiment that gives success its flavor"
chafi est déconnecté   Réponse avec citation
Vieux 26/04/2023, 17h28   #2
mcmomo
Avatar de mcmomo
Pouvoir de réputation: 26
mcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant future
Juste au cas où ton pin WLRZ....
---------- Post added at 03:28 PM ---------- Previous post was at 03:23 PM ----------
Envoyé par mcmomo Voir le message
Sinon essaie avec immotool....sinon se soir je t envoi
mcmomo est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to mcmomo For This Useful Post:
chafi (26/04/2023), yahiadiag (26/04/2023)
Vieux 26/04/2023, 18h27   #3
chafi
Avatar de chafi
S'il vous plaît j'ai besoin d'une bonne solution
Vieux 27/04/2023, 18h51   #4
mcmomo
Avatar de mcmomo
salam
regarde si sa te va
Type de fichier : bin BSI PEUGEOT PATRNER 2009 _Johnson control _95128 ORG-Virgin.bin (16,0 Ko, 18 affichages)
chafi (28/04/2023), yahiadiag (27/04/2023)
Vieux 28/04/2023, 10h01   #5
aza
Avatar de aza
aza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud of
salut mcmomo
votre dump n'est pas vierge l'ami ! ! !
VIN : VF3EBRHRH13347212
PIN : D3CW
salutations
aza est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to aza For This Useful Post:
chafi (28/04/2023), mcmomo (28/04/2023)
Vieux 28/04/2023, 10h54   #6
chafi
Avatar de chafi
Merci mes amis de m'aider problème résolu
The Following User Says Thank You to chafi For This Useful Post:
mcmomo (28/04/2023)
Vieux 28/04/2023, 14h36   #7
mcmomo
Avatar de mcmomo
Envoyé par aza Voir le message
salut mcmomo
PIN : D3CW
salutations
Salut l ami
OK bizzard je vais regarder après par curiosité....déjà on a même pas le pin...
Vieux 28/04/2023, 18h29   #8
mcmomo
Avatar de mcmomo
Salut l ami
J ai vérifier...tu es sûre que tu t'es pas tromper d eeprom...
The Following User Says Thank You to mcmomo For This Useful Post:
yahiadiag (28/04/2023)
Vieux 29/04/2023, 09h36   #9
aza
Avatar de aza
re salut mcmomo
nan l'ami c votre dump :
si-joint capture écran .... a droite le vin visible .
salutations
Type de fichier : jpg Capture.jpg (21,4 Ko, 18 affichages)
Vieux 29/04/2023, 09h41   #10
Myahmedidri
Avatar de Myahmedidri
Pouvoir de réputation: 9
Myahmedidri has a spectacular aura aboutMyahmedidri has a spectacular aura about
Mettre tout simplement le vin et pin en ffffffff et telecoder avec diagbox ,entrer le nouveau vin et pin adapter les clés.ça marche très bien.
Envoyé de mon Redmi Note 7 en utilisant Tapatalk
Myahmedidri est déconnecté   Réponse avec citation
Vieux 29/04/2023, 10h00   #11
mcmomo
Avatar de mcmomo
re salut mcmomo
salutations
Salut l ami
Quand même le vin de chafi et mon dump c est pas le même....
Bsi delphi psa toyota virgin ep 95128 OrlyMan Immobilizer dumps/solutions 1 10/02/2023 22h30
virgin eeprom 95128 valeo v46.21 dell 66 PSA Group Peugeot, Citroën 1 13/02/2021 11h38
virgin + PIncode ( eeprom 95128 valeo v46.21 dell 66 Immobilizer dumps/solutions 6 13/02/2021 11h24
Virgin BSI JC 308 Eprom 95128 UdsCanOnline Immobilizer dumps/solutions 8 02/02/2020 13h09
Fuseau horaire GMT +1. Il est actuellement 06h10.
