Vieux 03/06/2022, 08h06   #1
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 40
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Par défaut VAG DPF 3.26.11 Full (for Android device + ELM37)
With this application you can find out if the filter is really in the process of regeneration, if the regeneration is awaiting completion, how many kilometers have you traveled since the last regeneration, etc.
Core functions:
  • Display of 12 DPF filter parameters like soot mass accumulation in the filter, regeneration duration, km traveled and time passed since last regeneration, EGR valve closing, exhaust gas temperatures of the inlet, and outlet of DPF (Attention: data shown may vary depending on the engine type due to the presence of the parameters into the engine ECU)
  • Manual or automatic parameters update
  • Display, for all the parameters, of the previous value and the difference between the ****** and the previous value (only for automatic update delays different from 0 seconds)
  • Ability to exclude one or more parameter to increase the reading speed
  • Display of the filter filling percentage before reaching the filling limit that starts the execution of a field regeneration (standard regeneration controlled by the engine ECU)
  • Graphical display, using a progress bar, of the filling percentage value before starting a field regeneration or a service regeneration
  • Graphical display of the filter status: red filter for the regeneration phase (passive, field, or service) of the grey filter with different back internal areas depending on the filling percentage value
  • Display of extra data: adapter communication error counter, filter filling rating in µg/min, update time of all the 12 parameters, automatic update delay ******ly selected in the options menu
  • Notification bar icon to show an active connection and the auto-update process running.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Type de fichier : txt VAG DPF.txt (137 octets, 28 affichages)
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 21 Users Say Thank You to Aleksey-MS For This Useful Post:
AME (14/12/2022), autodiagauto (02/12/2024), chipshop (26/11/2022), darkfury07 (06/02/2023), drak999 (06/04/2023), gringo783 (22/10/2024), Honda (26/11/2022), joaonn13 (03/06/2022), luisfm (22/10/2023), mahfoud lichani (26/11/2022), MecaTech (08/04/2025), Molomolo (05/08/2024), paulamar (04/06/2022), rallye307 (29/05/2025), selouan (03/05/2024), toze60 (25/10/2024), transitforum (26/11/2022), vortex (03/06/2022), Woba (24/05/2024), zatazk (26/11/2022), zenata (03/06/2022)
Vieux 25/11/2022, 19h39   #2
Aleksey-MS
Added VAG ETKA 8.2 (1474)
Type de fichier : rar ETKA 8.2 (1474).rar (122,6 Ko, 35 affichages)
The Following 3 Users Say Thank You to Aleksey-MS For This Useful Post:
gringo783 (22/10/2024), mahfoud lichani (26/11/2022), MecaTech (08/04/2025)
Vieux 26/11/2022, 08h23   #3
mahfoud lichani
Avatar de mahfoud lichani
Envoyé par Aleksey-MS Voir le message
Salem
merci pour ETKA
est ce que l'on peut utiliser ce programme en étant connecté à internet sans risques?
bonne journée
Vieux 26/11/2022, 17h39   #4
Aleksey-MS
Envoyé par mahfoud lichani Voir le message
Salem
merci pour ETKA
bonne journée
Hello, this program is not afraid of connecting over the Internet.
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
Vieux 14/03/2023, 16h38   #5
Aleksey-MS
Added VAG DPF 3.27.12
MecaTech (08/04/2025), zebulons (24/04/2023)
Vieux 18/10/2023, 23h21   #6
Aleksey-MS
Added VAG DPF 3.28.12 Full
The Following User Says Thank You to Aleksey-MS For This Useful Post:
Vieux 30/04/2024, 12h02   #7
Aleksey-MS
The link was updated
Type de fichier : txt VAG DPF.txt (22 octets, 9 affichages)
chatgris08 (30/04/2024), gringo783 (22/10/2024), MecaTech (08/04/2025)
Vieux 02/10/2024, 16h49   #8
Aleksey-MS
Added VAG DPF 3.32.12
Vieux 25/10/2024, 16h35   #9
Aleksey-MS
Added VAG DPF v3.38.12
What's new:
- updated engine group 97 BETA configuration
- bug fix
chaoui05 (25/10/2024), MecaTech (08/04/2025)
Vieux 02/12/2024, 17h46   #10
Aleksey-MS
Added
VAG DPF 3.39.12
Type de fichier : txt VAG DPF.txt (27 octets, 7 affichages)
MecaTech (08/04/2025), rallye307 (29/05/2025)
Vieux 12/02/2025, 11h28   #11
Aleksey-MS
Added
VAG DPF 3.40.12
Carista 6.3.4 (for Android device) + Carista 6.4.1 beta-10 - Diagnose, Customize Aleksey-MS Mobile Windows CE, Android, iOS 31 04/09/2025 15h18
DashCommand APK full pour Android zenata Mobile Windows CE, Android, iOS 0 12/08/2020 20h47
BMWhat 15.82 Full (Android) - 29/1/15 DiagBmw GT1, OPS, SSS, ICOM 1 18/02/2015 18h18
Renault Key Device FULL AUTONOME didi_du_93000 Vente, Achat, Echange 1 27/05/2013 19h14
Fuseau horaire GMT +1. Il est actuellement 04h52.
