Précédent   Tlemcen Car electronics > Categorie principale > Tutoriels
Tutoriels Tutoriels pour vous aider.
Vieux 01/08/2023, 06h21   #1
OVERSPEED
Avatar de OVERSPEED
Pouvoir de réputation: 92
Par défaut Circuit anti lag turbo Subaru competition explication Video
Le circuit anti lag pour les turbos des Subaru rallye explique en Video
https://www.youtube.com/watch?v=aLGNlGCPlFw
Interessant
Au revoir
OS
The Following 8 Users Say Thank You to OVERSPEED For This Useful Post:
adiago (01/08/2023), Dane01000 (01/08/2023), dede83 (04/09/2023), Fouadtl (01/08/2023), mahfoud lichani (01/08/2023), MecaTech (05/09/2023), progreurLvl1 (01/08/2023), Sebos (05/09/2023)
Vieux 01/08/2023, 08h04   #2
progreurLvl1
Avatar de progreurLvl1
Pouvoir de réputation: 6
progreurLvl1 will become famous soon enoughprogreurLvl1 will become famous soon enough
Salut, super intéressant merci !
Commentaire du dessinateur du brevet de la techno anti lag présenté dans la vidéo
I just stumbled across this video, and was extremely pleased to see you cover a system I worked on during my SWRT days. I was the designer on this system, that was invented, developed brought to competition by Roland Broadbent. All the drawings from the patent you used were done by me. Some additional points:
1. No ignition system was used because the rules didn’t allow for a secondary ignition source after the engine spark plugs.
2. The idea came from a diesel French tank in the 1960’s that had what’s called a hyper charger, but that had its own ignition system.
3. Combustion in the chamber was initiated by the plate on the end of probe in the centre of the chamber, that flowed cherry red due to the hot exhaust gases coming from the engine. This plate restricted flow and reduced the top power of the engine. This later evolved to annular ring that was less restrictive to the flow through the chamber.
4. The boost tank used by Ford was illegal, but passed scrutineering when discovered. SWRT went the next rally with a bear barrel doing the same job. After that boost chambers on all cars were outlawed.
5. Different ALS systems were used on customer WRC cars.
6. A road car version was developed for STi by Prodrive, but never went to production due to cost and long term durability.
progreurLvl1 est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to progreurLvl1 For This Useful Post:
Dane01000 (04/09/2023), Fouadtl (01/08/2023), OVERSPEED (03/08/2023)
Vieux 04/09/2023, 20h36   #3
Dane01000
Avatar de Dane01000
Pouvoir de réputation: 7
Dane01000 will become famous soon enoughDane01000 will become famous soon enough
Eh ben, je ne m'était jamais posé autant de questions !!!
Dane01000 est déconnecté   Réponse avec citation
Video reparation pistes PCB / circuit OVERSPEED Tutoriels 0 07/04/2021 15h00
406 hdi- pression turbo electrovanne court-circuit. zefzafa85 PSA Group Peugeot, Citroën 4 06/07/2020 12h17
Master II2.2DCI 90CV problème huile dans circuit du turbo carto Automobile en général 6 28/09/2018 13h25
VIDEO GARRETT Turbo Installation star31 Mécanique générale 0 09/04/2014 07h27
video d'explication fap prodlt Tutoriels 0 25/12/2013 00h54
Fuseau horaire GMT +1. Il est actuellement 16h20.
