Vieux 10/09/2023, 13h20   #1
lemrid
Avatar de lemrid
lemrid is on a distinguished road
Par défaut mms flex issue edc17c64
hi,
I have a strange issue with mms flex & edc17c64
whatever i do, i ve an error writing & verifing (corrupt writing) @ the 25th sector of internal flash. (128kb)
this issue happended after an frf update + obd reading using flex + unlocking proccess while tring to write using flex obd.
tried boot, bench & obd, no way !!!!!!!!!!!!!!
suspecting an FPGA soldering issue (the ecu seems very hot)
any suggestions ???
I'm a keysearcher
lemrid est déconnecté   Réponse avec citation
Vieux 11/09/2023, 10h24   #2
lemrid
Avatar de lemrid
hi,
the car came running & working condition.
what I did :
- bench backup of the tcu & ecu
- updated ecu (frf) using odis e (ver 4943 to 8127) official frf database, checked, the car was running fine with dtc related to dpf & egr.
- pluged flex (obd), connect ok VR read. everything was fine as usual
- edited the vr (dpf & egr off), back to car write map
- the writing proccess started as usual but at 98% error (unlocking step)
- car wont start
- removed the ecu (btw the ecu seemed very hot) tried to write back the backup bench mode, result repeating 10 times the verification of the writing @25th sector. error
- tried boot protocol, same result stucks @ 25th
that's all
I'm a keysearcher
Edc17c64 brahim chafa3 Immobilizer dumps/solutions 1 24/06/2022 22h05
dpf off edc17c64 nizar Chiptuning 4 28/06/2018 16h53
Airbag Issue BackONct Section for english users 7 12/09/2017 22h54
Peugeot 307SW HDi BSM issue. utut20 Mécanique générale 3 16/11/2014 04h19
Another driver issue with ECM6.3 zak5665 Chiptuning 0 04/12/2009 20h38
Fuseau horaire GMT +1. Il est actuellement 19h24.
