Vieux 15/09/2023, 21h11   #1
scott_311
Avatar de scott_311
scott_311 is a splendid one to beholdscott_311 is a splendid one to beholdscott_311 is a splendid one to beholdscott_311 is a splendid one to beholdscott_311 is a splendid one to beholdscott_311 is a splendid one to beholdscott_311 is a splendid one to behold
Par défaut Aide pour le codage long SKODA FabiaII Phase 2 1.6 TDi
j'ai besoin du codage pour une SKODA FabiaII Phase 2 1.6 TDi FAP 16V 90 cv
voila le vin: M10SKDVP002W400
si besion d'autre information je vous envois.
merci pour tous votre aide
scott_311 est déconnecté   Réponse avec citation
Vieux 15/09/2023, 21h29   #2
Nicolas13007
Avatar de Nicolas13007
Nicolas13007 is a name known to allNicolas13007 is a name known to allNicolas13007 is a name known to allNicolas13007 is a name known to allNicolas13007 is a name known to allNicolas13007 is a name known to all
Codage quoi ABS ? CLEFS ? ECU MOTEUR ?
Nicolas13007 est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to Nicolas13007 For This Useful Post:
Dav (16/09/2023), everson29 (15/09/2023), scott_311 (16/09/2023), vortex (16/09/2023)
Vieux 16/09/2023, 10h23   #3
scott_311
Avatar de scott_311
codage long abs de la voiture
bien a vous et merci pour votre aide
Vieux 16/09/2023, 10h41   #4
Dav
Avatar de Dav
Pouvoir de réputation: 54
Dav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond repute
T'aurais pas un log vcds ? Faut d'autres infos sur le bloc abs (hw ?)
Dav est déconnecté   Réponse avec citation
The Following User Says Thank You to Dav For This Useful Post:
Vieux 16/09/2023, 13h12   #5
scott_311
Avatar de scott_311
voila les infos du bloq
(Bosch ABS/ESP 8.2i / 6RO-907-37X-ESP82.CLB)
No. VAG: 6RO 907 379 AL
Code logiciel: Codage long
Piéce: ESP8.2i front H05 0001
VIN : TMBEJ25J7C3070842
Vieux 16/09/2023, 13h33   #6
marcodu45
Avatar de marcodu45
marcodu45 is a glorious beacon of lightmarcodu45 is a glorious beacon of lightmarcodu45 is a glorious beacon of lightmarcodu45 is a glorious beacon of lightmarcodu45 is a glorious beacon of light
Slt,
sans trop y croire... le soft options cachées me donne :
410124DB217300B3822A24E284D200401300
à tester
marcodu45 est déconnecté   Réponse avec citation
The Following User Says Thank You to marcodu45 For This Useful Post:
Vieux 16/09/2023, 13h39   #7
aza
Avatar de aza
Pouvoir de réputation: 31
salut scott_311
a essayer bien sur ! ! !
salutations
Type de fichier : jpg Capture.jpg (19,1 Ko, 32 affichages)
The Following 2 Users Say Thank You to aza For This Useful Post:
Vieux 16/09/2023, 13h40   #8
aza
Avatar de aza
long code : 410124DB217400B2822D24E684D300400000
The Following User Says Thank You to aza For This Useful Post:
Vieux 16/09/2023, 13h49   #9
scott_311
Avatar de scott_311
merci a vous tous je vais tester cela et je vous fait un retour si c'est ok.
merci encor une fois pour votre aide
Vieux 16/09/2023, 13h51   #10
Dav
Avatar de Dav
J'avais besoin d'un cobaye :-) A priori je trouve pas le même code qu'au dessus, après confirme juste que c'est bien un moteur CAYB, boite manuelle ?
A la main, je trouve :
410128DB417400B2822D14E682D300421000
The Following 5 Users Say Thank You to Dav For This Useful Post:
geygey521 (03/10/2023), scott_311 (17/09/2023), skeuf (17/09/2023), vortex (16/09/2023), yahiadiag (17/09/2023)
Vieux 17/09/2023, 11h15   #11
scott_311
Avatar de scott_311
bonjour a tous
je vous remercie tous pour votre aide.
le codage long qui a marche c'est celui de @Dav et je vous remercie pour ton aide.
a ce que c'est possible de nous dire avec quoi ta pu optunu le bon code, car j'ai acheté tous les softs qui font le calcul et rie d'eux a marche.
je vous remercie pour tous les aides et les informations.
bien a vous
The Following 2 Users Say Thank You to scott_311 For This Useful Post:
Dav (17/09/2023), Moon (17/09/2023)
Vieux 17/09/2023, 12h21   #12
Dav
Avatar de Dav
Coool ! Je ne l'ai pas fait avec un soft, mais à l'aide de mes neurones... Ca fait un petit moment que je m'y intéresse, du coup tu tombais à pic pour vérifier !
Mais t'inquiète, si tu veux un soft qui fonctionne, tu seras servi dans un petit moment :-)
The Following 7 Users Say Thank You to Dav For This Useful Post:
everson29 (17/09/2023), geygey521 (03/10/2023), Moon (17/09/2023), phil1 (17/09/2023), POCOYO (17/09/2023), pp08 (17/09/2023), scott_311 (17/09/2023)
Vieux 17/09/2023, 13h14   #13
scott_311
Avatar de scott_311
moi je suis prés a te faire la vente de ton soft et la pub.
bien a vous
Dav (17/09/2023), pp08 (17/09/2023)
Vieux 17/09/2023, 14h33   #14
pp08
Avatar de pp08
Pouvoir de réputation: 35
Envoyé par Dav Voir le message
ça sent la mise a jour de BEUT....
pp08 est connecté maintenant   Réponse avec citation
The Following 4 Users Say Thank You to pp08 For This Useful Post:
Alessiapia14 (14/01/2024), Dav (17/09/2023), scott_311 (17/09/2023), yahiadiag (17/09/2023)
Codage long abs G6 geygey521 ABS, ESP, DSC 9 17/04/2023 17h20
Codage long chaoui05 Vw, Audi, Skoda, Seat, Bentley 10 17/04/2023 06h07
Codage long YUMBO ABS, ESP, DSC 18 11/02/2023 09h40
CHERCHE long codage pour ABS VW POLO 6R0907379S hakim087 ABS, ESP, DSC 5 08/05/2022 17h31
besoin de l'aide pour desactiver l'egr skoda 1.6l PIC16F84 Chiptuning 1 01/03/2021 11h18
Fuseau horaire GMT +1. Il est actuellement 07h25.
