Vieux 30/03/2024, 10h10   #1
Mutasim
Avatar de Mutasim
Mutasim is an unknown quantity at this point
Par défaut Renault Captur 2014 1.2tce
I've Renault Captur 2014 1.2 TCe, and I'm still getting those codes DTC019064 Fuel rail pressure sensor implausible signal, DTC059713 coolant circuit switching solenoid valve open circuit, DTC1525F3 consistent multiplex signals for CC/SL the data supplied to the cruise control or speed limiter are not correct. As per now I've changed fuel rail pressure sensor, high pressure fuel pump, all spark plugs, injectors, thermostat housing, oxygen sensor and cleaned dpf but still those codes are present.
Mutasim est déconnecté   Réponse avec citation
Captur 2014 : vol de carte electronico programmation & synchronisation de clé 22 13/06/2021 21h32
carte captur 2014 canaja26 Programmeur de clé 32 13/09/2020 21h14
Vin renault captur Karim69 Transponder, code pin 5 19/08/2019 21h36
original Renault Clio III 1.2TCE 101hp kinetic Fichiers d'origine, carto, dump, fullbackup 1 04/06/2019 16h59
renault captur Meziane93 Airbag 4 13/06/2018 19h17
Fuseau horaire GMT +1. Il est actuellement 14h50.
