Discussion fermée
Vieux 22/06/2009, 21h23   #1
abesaabdou200
Banned
Avatar de abesaabdou200
abesaabdou200 is an unknown quantity at this point
Par défaut code bmw
bmw business ph703031051309
bmw RCC103-00
the radio display disabled , plz solution .
here is my dump can you edit it . thanks
Type de fichier : rar ph7030_24c64.rar (1,8 Ko, 14 affichages)
abesaabdou200 est déconnecté
Vieux 22/06/2009, 22h52   #2
massiniss
Avatar de massiniss
massiniss has a little shameless behaviour in the past
Par défaut re bmw
Envoyé par abesaabdou200 Voir le message
bmw RCC103-00
please more info about car radio. what do u mean with display disabe?
massiniss est déconnecté
Vieux 22/06/2009, 23h01   #3
nigrou
Avatar de nigrou
nigrou is a splendid one to beholdnigrou is a splendid one to beholdnigrou is a splendid one to beholdnigrou is a splendid one to beholdnigrou is a splendid one to beholdnigrou is a splendid one to beholdnigrou is a splendid one to behold
Voila essyer ce dump
Type de fichier : rar ph7030_24c64.rar (3,5 Ko, 15 affichages)
nigrou est déconnecté
Vieux 23/06/2009, 00h29   #4
abesaabdou200
Banned
merci je veut tester
sur l'ecran est ecrit (disabled) svp solution
Dernière modification par abesaabdou200 ; 23/06/2009 à 00h32.
Vieux 23/06/2009, 10h33   #5
nigrou
Avatar de nigrou
Radio Code & DISABLED Repair Service
BMW Business
As originally fitted to :
BMW
If you are trying to fit this radio to a different vehicle, then you may find yourself with the Error message of "DISABLED". This stereo is electronically paired, or "Married" to the engine management system of the vehicle it came out of using very sophisticated CAN-BUS system technology.
When it is first powered up, it will communicate with the vehicle, and if communication has been successfull, it will power up in the normal way.
However, if removed and refitted into a different vehicle other than the original one, it will not recognise the encrypted CANBUS identification of the new car, and will instead display an error message of "DISABLED".
This Radio cannot therefore be transferred from one car to another, unless it has first been reset back into its original "Delivery Mode" with the internal CAN-BUS data memory reprogrammed for use with the new vehicle.
BMW Dealers may tell you that this stereo cannot be reprogrammed to go into another vehicle, but then thats what they said about other models, before we managed to reset the CAN-BUS system !!
We can reset the DISABLED Error message for this radio, and return it allowing it to be used in a different vehicle, but you will need to send the unit to our workshop for this work to be carried out. Approx turnaround time is 48 hours from receipt to dispatch.
This radio is bolted in place by two bolts, and these will be hidden beneath the dashboard trim. Removal of the trim will depend largely on the vehicle it is fitted to, but should not present any real problems. Please consult your service manual if you are unsure how to go about this. Once the two bolts that secure the radio frame have been removed, the stereo will come out and can then be unplugged.
essyer ce dump
Type de fichier : rar ph7030_24c64.rar (1,7 Ko, 17 affichages)
Dernière modification par nigrou ; 23/06/2009 à 10h44.
Vieux 23/06/2009, 17h22   #6
abesaabdou200
Banned
svp aide j'ait teté tous ses dump rien à marcher
Discussion fermée
Fuseau horaire GMT +1. Il est actuellement 11h34.
