Vieux 09/05/2025, 01h48   #1
SRA
Avatar de SRA
Pouvoir de réputation: 7
SRA will become famous soon enoughSRA will become famous soon enough
Arrow Jeep - Chrysler - Dodge IMMO Tools (APNT + AEMT-Maxx + Chysler v3)
______________________________________________
AEMT-MAXX IMMO Tool J2534 (2005/2022)
AEMT MAXX official website:
AEMTMAXX.com
Cost 105$ AEMT MAXX is a tool that evolved from an early SKIM and VIN tool developed by ECUunlock.
The tool allowed the user to make a SKIM-activated PCM into a SKIM-desactivated PCM.
_Supported ECU Types From 1995 to 2008 Model.
SCI ECU, JTEC, SBEC, NGC1, NGC2, NGC3, CUMMINS
Disable SKIM: IMMO OFF
SRI Mileage Edit: Modify the Service Reminder Indicator mileage.
VIN Editor: Edit Vehicle Identification Numbers.
Read Memory: Access and read flash memory.
Write Memory: Write data back to the flash memory.
_ Supported CAN BUS Systems From 2005 to 2021 Models.
NGC3, NGC4, NGC4A, GPEC, GPEC2, GPEC2A, GPEC3, CUMMINS
Read EPROM: Read data from EPROM.
Write EPROM: Write data back to EPROM.
Write Memory: Write flash memory data efficiently.
Click here for more Details about AEMT-MAXX Tool
Video link:
https://www.youtube.com/watch?v=ME9mMWrHT_E&t
APNT Chrysler IMMO OFF J2534 (2005/2019)
Cost 70$, use it with J2534 devices,
to edit the SKIM security and VIN change.
APNT functions: (chrysler-dodge-jeep)
- READ ECU INFO
- SKIM DISABLE
- SRI MILEAGE EDIT
- VIN EDITOR
** for gas ecu's 1995-2019
** for diesel from 1998 -2013
list supported ecu's:
( siemans and cummins ecu's support vin read and write only )
make sure your j2534 device supports sci ( j2610 ) and can bus before purchase
apnt is benchtop programming tool.
(most use it in vehicle with no issues. i can not guarantee it supports all in vehicle programming )
apnt will disable skim but!!! if you install ecu into a vehicle with a skim module it will re-enable skim in that vehicle .
you will need to unplug skim module if you are using for this purpose.
Be careful:
if you unplug the skim module to disable skim you will lose keyless entry and tire pressure monitor functionality
Video link:
https://www.youtube.com/watch?v=Ok3HQFJtH_s
Chrysler IMMO OFF Tool v3.0
Cost 43$ FCA Group IMMO OFF by Dumps:
Antena Vatansever, Kalibre (24lc16)
Anten Cherokee (MCU 9S12DB128 eeprom)
RFH V1 Joumey 2011+, Şarj Cihazı, 300M (MCU 9S12EXQ384 eeprom)
TIPGW Cherokee (MCU 9S12DT256 eeprom)
Compu Motorola V1'in hafızası var (95320)
Compu Motorola Memoria 195080)
Compu Motorola Memoria 2(95080)
RFH V2 Grand Cherokee, Durango (MCU 9S12EXQ384 eeprom)
RFH V3 Pusula (MCU 9S12EXQ384 eeprom)
RFH V4 Dart (MCU 9S12EXQ384 eeprom)
RFH V5 2017+ (95640)
Bilgisayar Motorola V2 hafızalı (95320)
BCM RAM SPC5606B (D-FLAŞ)
Price for the 3 software's is only 120$ if it's needed.
B.REGRADS
SRA est déconnecté   Réponse avec citation
The Following User Says Thank You to SRA For This Useful Post:
alpha-b (20/05/2025)
immo, skim, tool, vin, write
CDA 6.15.188 Release 15-04-2023 ( Jeep - Chrysler- Dodge ) SRA Vente, Achat, Echange 0 08/12/2023 15h41
CDA 6.15.188 Release 15-04-2023 ( Jeep - Chrysler- Dodge ) SRA Vente, Achat, Echange 0 15/09/2023 02h16
CDA 6.15.188 Release 15-04-2023 ( Jeep - Chrysler- Dodge ) SRA Vente, Achat, Echange 1 15/09/2023 02h08
Android : Alfa/Fiat/Jeep/Chrysler/Dodge/Jeep/Peugeot/Citroen zenata Fiat, Alfaromeo, Lancia 10 20/10/2019 21h51
Jeep - Chrysler - Dodge Developer Tool TAGRART Logiciel & autres documentations général 3 21/01/2013 19h00
Fuseau horaire GMT +1. Il est actuellement 13h47.
