Vieux 18/07/2012, 10h34   #1
Mezz
Avatar de Mezz
Mezz is an unknown quantity at this point
Par défaut Megane II
Hello
I have Megane II with problems.Battery is dead so we change new one,but car want s start,when i put keycard and press brake+start nothing happens,but wheel is unlock always,so i think that is problem in steering lock,what you think and does anybody have any advice for this problem ?
I read steering lock eeprom(24c04) and can anybody check is everything ok with file ?
And also i can t lock and unlock the car by keycard? i test keycard with my tester and it s work fine there is frequency and also i read code for start engine also it s ok,both cards are ok.
So please help me with advice what to do,what to check and so on ....
Many thanks...
Bruno
Type de fichier : rar 24c04.rar (148 octets, 13 affichages)
Mezz est déconnecté   Réponse avec citation
The Following User Says Thank You to Mezz For This Useful Post:
Mecatec (21/07/2012)
Vieux 18/07/2012, 12h58   #2
raisinsec
Avatar de raisinsec
raisinsec is a glorious beacon of lightraisinsec is a glorious beacon of lightraisinsec is a glorious beacon of lightraisinsec is a glorious beacon of lightraisinsec is a glorious beacon of light
Hi
THE BEST IS YOU TO DO A DIAGNOSTIC
raisinsec est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to raisinsec For This Useful Post:
Mecatec (21/07/2012), Mezz (19/07/2012)
Vieux 18/07/2012, 13h32   #3
mick711
Avatar de mick711
Megane 2 de quelle année et quelle motorisation ?
Avez vous fait une lecture de code défaut sur tous les calculateurs et si oui y a t'il des défaut et encore si oui lesquels ?
En lecture de paramètre la carte est elle reconnu ? Le code antidémarrage est il bon ?
Mince pas vu en anglais ^^
Fault code ?
led for immobiliser light ?
Autocom CDP+
Texa TXT IDC4 Plus Car
USB KKL
ELM
The Following 2 Users Say Thank You to mick711 For This Useful Post:
Vieux 18/07/2012, 19h57   #4
Mezz
Avatar de Mezz
Hello
Year of the car is 2004. and engine is 1.5Dci Ecu is Delphi.
I enter with diagnostic in Steering lock and there are two errors :
One is ECU
Second ECU memory
And i change today another one steering lock and still the same erros in the steering lock,why? :S
Lamp of immobiliser code is always ON non stop.
Tommorow i will get original diagnostic CLIP for renault then i can put every errors with codes.
Any advice?
Many thanks...
Bruno
Mecatec (20/07/2012)
Vieux 19/07/2012, 00h06   #5
mick711
Avatar de mick711
Only new if it's a old they don't work or if you change chip inside with chip in old module .
Autocom CDP+
USB KKL
ELM
Mecatec (20/07/2012), Mezz (19/07/2012)
Vieux 19/07/2012, 09h37   #6
Mezz
Avatar de Mezz
Yes i know for that of course that i change eeprom a put original but still the same .... :(
Vieux 19/07/2012, 11h18   #7
mick711
Avatar de mick711
Have you DF code please ?
Autocom CDP+
USB KKL
ELM
The Following User Says Thank You to mick711 For This Useful Post:
Vieux 20/07/2012, 23h59   #8
Mecatec
Avatar de Mecatec
Pouvoir de réputation: 23
Mecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to behold
hi friend. if the lamp of the immobilizer is flashing . the key is not recognized
if the lamp switches off after some seconds so the key is recognized
If the lamp remained lit, it means the ecu is damaged
so check ecu grounds and +++ or change it
good luck
Mecatec est déconnecté   Réponse avec citation
Vieux 23/02/2015, 22h18   #9
GUESSABOSS
Avatar de GUESSABOSS
GUESSABOSS will become famous soon enoughGUESSABOSS will become famous soon enough
Bonsoir;
Vérifier en premier lieu l'alimentation d'+ permanent, dans le cas où il est présent, essaye de dumper l'eprom avec des FFFFFFF sinon contrôle les deux fusibles sur l'upc (5A et 15A).
L'homme n'est un homme que parmi les hommes
GUESSABOSS est déconnecté   Réponse avec citation
Fuseau horaire GMT +1. Il est actuellement 15h46.
