Vieux 24/07/2012, 10h55   #1
Mezz
Avatar de Mezz
Mezz is an unknown quantity at this point
Par défaut Hello
I need help or advice about one thing :
In last few months i get many Renault CLIO II with problem to start the engine(flashing immo lamp on dashboard).
I check keys,they are ok and also read code with Abritus,i check antenna,she is also okey,i check the UCH it s also ok,so what is the problem with this cars?
Does anybody fix this problems? everything is ok but lamp is flashing.
For example i can start 20 times car normal and for few moments or for one hour it s start to flash lamp,so really i don t understand it what happens with this cars ?
It s maybe problem in wiring or ?
Many thanks...
Bruno
Mezz est déconnecté   Réponse avec citation
Vieux 26/07/2012, 19h45   #2
pimo
Avatar de pimo
do you speak french ?
USE GOOGLE TRANSLATOR
The Following 2 Users Say Thank You to pimo For This Useful Post:
charifcharif (26/07/2012), electro_bordeaux1 (27/07/2012)
Vieux 27/07/2012, 02h53   #3
Mecatec
Avatar de Mecatec
Pouvoir de réputation: 23
Mecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to behold
Envoyé par Mezz Voir le message
Many thanks...
Bruno
hi the problem may be in the eprom of the ecu check it and try to edit the dump to immo off if no change the eprom of the ecu it will be ok
good luck
Mecatec est déconnecté   Réponse avec citation
Vieux 27/07/2012, 16h44   #4
bs-express
Avatar de bs-express
bs-express will become famous soon enough
il se peut que vous aviez un problème au niveau des connecteurs au dessous de la plaque à fusibles du coté moteur ....... si non c'est un problème de câblage entre les dits connecteurs et le calculateur d'injection.
Voila un poste qui partage une documentation concernant le fonctionnement de IMMO Renault, c'est très utile car il te donne l'explication pour chaque symptôme ..... mais c'est en français .......... demande le passe à dell 66
http://www.tlemcen-electronic.com/fo...t=immo+renault
bs-express est déconnecté   Réponse avec citation
Vieux 01/08/2012, 23h05   #5
Mezz
Avatar de Mezz
Envoyé par jose Voir le message
Hi
That happends many times...resold all smd from remote control..
Jose
Hello
I resolder everything ...keys...uch ...and still the same ...but i don t understand why is happen that...that car won t start ...and after he wanna start ....
Many thanks...
The Following User Says Thank You to Mezz For This Useful Post:
Mecatec (02/08/2012)
Vieux 02/08/2012, 03h23   #6
Mecatec
Avatar de Mecatec
Hello
Many thanks...
hi do you check the key batteries perhaps they are low
good luck
Vieux 02/08/2012, 03h27   #7
Mecatec
Avatar de Mecatec
Envoyé par zekhrouf Voir le message
good luck
and dont forget to clean the key
thanks
Vieux 02/08/2012, 11h50   #8
verdi
Avatar de verdi
verdi is a jewel in the roughverdi is a jewel in the roughverdi is a jewel in the rough
good luck
the battery of the key has no effect on immobilizer is just that serves the FUNCTIONING of centralization
verdi est déconnecté   Réponse avec citation
The Following User Says Thank You to verdi For This Useful Post:
Mecatec (03/08/2012)
Vieux 03/08/2012, 05h30   #9
Mecatec
Avatar de Mecatec
But in some cars May cause immo problème friend
Thanks
Fuseau horaire GMT +1. Il est actuellement 12h33.
