Vieux 13/05/2013, 23h06   #1
hugopinho
Avatar de hugopinho
hugopinho is on a distinguished road
Par défaut IAW4nr.c2
Hi friends
I have a Renault Clio, 2002, 1.2, 16v With the following ECU:
Magneti Marelli
IAW4nr.c2
8200162381
8200178931
I need to replace the original ECU, that is damaged.
I have allready a compatible ECU, but I need to code it.
The eeproom is a hybrid 95160. How can I read it? Can anyone help me.
Thanks and regards in advanced
Pinheiro
hugopinho est déconnecté   Réponse avec citation
Vieux 13/05/2013, 23h27   #2
Amine-TE
Fondateur
Avatar de Amine-TE
Pouvoir de réputation: 1330
check on immokiller, there is a picture to read it by wires.
Je ne donne pas d'aide en privé.
The Following User Says Thank You to Amine-TE For This Useful Post:
hugopinho (14/05/2013)
Vieux 18/05/2013, 19h14   #3
hugopinho
Avatar de hugopinho
Par défaut solution
After trying to read the eprom with no result I have got a solution that works 100%:
First
I have bought a used ecu IW5NR.C5 and program the eeprom with the file in attach.
Second
Then I cut the wire from the connector (red 12V permanent)- as you can see in the picture and INSIDE ECU CONNECT PIN L4 with PIN M4 (see picture in the attach).
Type de fichier : rar remove.rar (396 octets, 5 affichages)
The Following User Says Thank You to hugopinho For This Useful Post:
jah83 (19/05/2013)
Fuseau horaire GMT +1. Il est actuellement 08h23.
