Vieux 10/11/2013, 10h58   #1
mirek
Avatar de mirek
mirek is an unknown quantity at this point
Par défaut citroen c3 code p0463
citroen c3 1.1i diagnostic diagbox code p0463
code repeat every 10km.
please help repair car.
mirek est déconnecté   Réponse avec citation
Vieux 10/11/2013, 12h00   #2
Breizhelec
Avatar de Breizhelec
Pouvoir de réputation: 56
hi, what is the problem with the car, the p0463 is: fuel level sensor
Vieux 10/11/2013, 12h40   #3
mirek
Avatar de mirek
Envoyé par damdam Voir le message
car no problem. diagbox repeating error code but car no problem
Vieux 10/11/2013, 12h59   #4
hi, the trouble is un too the tank petrol
the level petrol! under the rear right seat
exuse my inglish writing
so long
Vieux 10/11/2013, 12h59   #5
mirek
Avatar de mirek
cable are in order, sensor cleaning. despite the repeated errors. Why change when the sensor is not a visual bug?
Vieux 10/11/2013, 13h09   #6
you must change the level sensor,
when you have the trouble , have you only the light on or more ??
Vieux 10/11/2013, 13h13   #7
mirek
Avatar de mirek
car no visual problem, no light obd control, only fault in memory
Vieux 10/11/2013, 13h21   #8
let it, maybe histories trouble do with the diagnostic box
some on can doo that
Vieux 10/11/2013, 13h22   #9
Breizhelec
the resistance of the sensor must not be good or look in the bsi configuration
Vieux 10/11/2013, 13h25   #10
salut damdam, pas de reclamation de ce défaut juste un dtc en memoire
des fois ca sert a rien de s'acharner au zero defauts, de plus ca marche donc ???
a+
bon dimanche
Vieux 10/11/2013, 13h30   #11
mirek
Avatar de mirek
error will not solve until it starts to manifest itself. Thank you for answering
The Following User Says Thank You to mirek For This Useful Post:
jphp (10/11/2013)
Vieux 10/11/2013, 13h36   #12
great , put the Thanks button
so long, friend
mirek (10/11/2013)
Vieux 10/11/2013, 13h51   #13
Breizhelec
a+
bon dimanche
oui c'est clair , c'est pas un défaut très gênant
code pin citroen toufiq Transponder, code pin 0 08/05/2013 20h00
code pin citroen baste59 Transponder, code pin 3 25/12/2012 23h44
code pin citroen shasse Transponder, code pin 2 08/05/2012 13h34
code pin citroen c4 baste59 Transponder, code pin 2 02/03/2012 15h48
Citroen pf1 (a) car code mourad44 Autoradio et Navigateur GPS 4 17/08/2010 05h12
Fuseau horaire GMT +1. Il est actuellement 18h43.
