Discussion fermée
Vieux 27/07/2014, 16h13   #1
Verdun
Avatar de Verdun
Verdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud of
Par défaut Immo off edc15C34
Bonjour a tous je me retrouve en galère ma 206 redémarre plus a cause d un problème de bsi quand je passe pp2000 il me dit calculateur en attente de réponse du bsi et je doit déplacer la voiture pour racheter un kit démarrage donc j aurai besoin d une immo off
merci a tous calculo 206 EDC16C34.bin
Verdun est déconnecté
The Following User Says Thank You to Verdun For This Useful Post:
COTECH00 (19/10/2014)
Vieux 27/07/2014, 18h07   #2
dingo307
Avatar de dingo307
dingo307 is a glorious beacon of lightdingo307 is a glorious beacon of lightdingo307 is a glorious beacon of lightdingo307 is a glorious beacon of lightdingo307 is a glorious beacon of light
essai sa
mais rien de sur d’ailleurs si des pro peuvent vérifier car je débute dans le domaine
Type de fichier : bin calculo 206 EDC16C34 off.bin (2,0 Ko, 4 affichages)
dingo307 est déconnecté
Vieux 27/07/2014, 18h16   #3
dingo307
Avatar de dingo307
ou celui la
Type de fichier : bin calculo 206 EDC16C34 off 2.bin (2,0 Ko, 2 affichages)
Vieux 27/07/2014, 18h40   #4
amrougafsa
Avatar de amrougafsa
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
c'est la calculateur du NEGOCAUTO33 avec le pin code G9KC et j'ai deja lui faire un vierge pour le BSI
bon en tous cas voici ton off
Type de fichier : rar off edc16c34 ok.rar (699 octets, 10 affichages)
amrougafsa est déconnecté
Vieux 27/07/2014, 19h26   #5
Verdun
Avatar de Verdun
Oui exact mais sa a pas regler le souci meme avec le bsi vierge j arriver pas a le reprogammer merci pour l immo off sa a marcher j ai pu deplacer la voiture pas rien dans la voiture a votre avis je doit acheter un bsi d occas ou un kit complet
Vieux 27/07/2014, 21h10   #6
amrougafsa
Envoyé par Verdun Voir le message
non juste un BSI d'occasion et tiens moi au courant je te fait 2 vierge pour le BSI et le calculateur moteur normalement sa dois marcher .
a+
The Following User Says Thank You to amrougafsa For This Useful Post:
Verdun (28/07/2014)
Vieux 28/07/2014, 01h10   #7
Verdun
Avatar de Verdun
ok merci je vais en chercher demain matin passe je te tiens au jus
Vieux 29/07/2014, 17h48   #8
Verdun
Avatar de Verdun
Donc probleme regler j ai pris un bsi et ressouder l eeprom et j ai tout telecoder manuellement avec pp2000
Discussion fermée
Edc15c34 partner 1,6 hdi immo off milerk Immobilizer dumps/solutions 4 05/04/2012 05h00
Fuseau horaire GMT +1. Il est actuellement 18h03.
