Vieux 07/10/2014, 16h32   #1
stephane
Avatar de stephane
Pouvoir de réputation: 120
Par défaut immo off c8
Salutations
J aurais besoin d'un immo off pour un c8
0 281 011 133 96 474 746 80 EDC 15C2 eprom 95p08
Merci d avance
Type de fichier : bin IMMO C8 0 281 011 133 EDC15C2 95P08.bin (1,0 Ko, 15 affichages)
Vieux 07/10/2014, 17h00   #2
Nizar-maoukil
Avatar de Nizar-maoukil
Pouvoir de réputation: 23
Nizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud of
hi
i can make this off if u poste the flash dump
regards
Mercedes esl repair programing and renew
bmw E90 and E60 esl off ( car runs without esl )
regards
Nizar-maoukil est déconnecté   Réponse avec citation
The Following User Says Thank You to Nizar-maoukil For This Useful Post:
stephane (07/10/2014)
Vieux 07/10/2014, 17h16   #3
carspeed
Avatar de carspeed
carspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to behold
Voici ton immoff
le MP dans ta boite
Type de fichier : rar IMMO OFF C8 0 281 011 133 EDC15C2 95P08.rar (403 octets, 9 affichages)
carspeed est déconnecté   Réponse avec citation
The Following User Says Thank You to carspeed For This Useful Post:
Vieux 07/10/2014, 17h22   #4
Nizar-maoukil
salut carspeed
quel soft t'as utiliser
t'as deja tester cette solution
cldt
regards
Vieux 07/10/2014, 17h23   #5
stephane
Avatar de stephane
Envoyé par Nizar-maoukil Voir le message
hi
regards
Hi the file is attached
Vieux 07/10/2014, 17h24   #6
stephane
Avatar de stephane
Merci carspeed retour vendredi soir
Vieux 07/10/2014, 17h27   #7
carspeed
Avatar de carspeed
salut carspeed
cldt
CAR TOOL V 3.0
Nn le fichier ne pas teste
Vieux 07/10/2014, 17h31   #8
carspeed
Avatar de carspeed
OK stephane bon courage
ne oublie pas de poste la résultat
Vieux 07/10/2014, 17h38   #9
Nizar-maoukil
t'a oublier de poster le dump de la flash
cldt
regards
Vieux 07/10/2014, 19h30   #10
r1lef
Avatar de r1lef
Pouvoir de réputation: 62
off sur flash là-dessus ...
Vieux 11/10/2014, 22h28   #11
stephane
Avatar de stephane
C est un 2003 il me semble que de cetye année c est uniquement sur la 5p08 non ?
Carspeed ca ne marche pas
Vieux 11/10/2014, 23h02   #12
ryosaeba
Avatar de ryosaeba
tu as une broche ou 3 broches sur ton edc15c2 ?
stephane (12/10/2014)
Vieux 12/10/2014, 08h46   #13
stephane
Avatar de stephane
Salutations c est un 3 broches
Vieux 12/10/2014, 09h08   #14
techtronic1
Avatar de techtronic1
Slt normalement immo off c sur la flach si sa marche pa on fe aussi sur la 95p08
Vieux 12/10/2014, 12h12   #15
ryosaeba
Avatar de ryosaeba
si 3 plugs flash 29f400bt tu peux le faire avec le soft d'ecuserver
The Following 2 Users Say Thank You to ryosaeba For This Useful Post:
Nizar-maoukil (12/10/2014), stephane (12/10/2014)
Fuseau horaire GMT +1. Il est actuellement 18h14.
