Vieux 28/10/2014, 11h12   #1
rahmani2008
Avatar de rahmani2008
rahmani2008 is a jewel in the roughrahmani2008 is a jewel in the roughrahmani2008 is a jewel in the roughrahmani2008 is a jewel in the rough
Par défaut immo off
immo off pour picasso 2.0 hdi merci
Type de fichier : rar 29F400BT picasso0281011084 1037364198ORI3coùùecteurs.rar (163,2 Ko, 24 affichages)
rahmani2008 est déconnecté   Réponse avec citation
Vieux 28/10/2014, 12h09   #2
amrougafsa
Avatar de amrougafsa
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
Bonjour voici un immo off deja testé pour EDC15c2 3 plug
Type de fichier : rar IMMO EDC15C2 29F400BT-OFF teste ok.rar (166,7 Ko, 160 affichages)
amrougafsa est déconnecté   Réponse avec citation
The Following User Says Thank You to amrougafsa For This Useful Post:
rahmani2008 (28/10/2014)
Vieux 28/10/2014, 12h42   #3
rahmani2008
merci bien pour l'immo off le moteur demarre bien mais le ventillateur marche sous contact et motuer tournant et ne s'arrete pas que lorsque je coupe le motuer bizare non
Vieux 28/10/2014, 13h08   #4
MOURAD SPCMAX
Avatar de MOURAD SPCMAX
MOURAD SPCMAX is a splendid one to beholdMOURAD SPCMAX is a splendid one to beholdMOURAD SPCMAX is a splendid one to beholdMOURAD SPCMAX is a splendid one to beholdMOURAD SPCMAX is a splendid one to beholdMOURAD SPCMAX is a splendid one to beholdMOURAD SPCMAX is a splendid one to behold
Wink
Envoyé par rahmani2008 Voir le message
pour toi!! :)
Type de fichier : rar 29F400BT picasso0281011084 immo off okay.rar (164,0 Ko, 22 affichages)
FILE SERVICE_CHIP TUNING_DISABLE ADBLUE_Xentry - DAS 2015
MOURAD SPCMAX est déconnecté   Réponse avec citation
The Following User Says Thank You to MOURAD SPCMAX For This Useful Post:
Vieux 28/10/2014, 14h02   #5
rahmani2008
Envoyé par MOURAD SPCMAX Voir le message
pour toi!! :)
merci bien mourad c le meme immo off que j'ai utilisé ,au debut le moteur ne demarre pas ,j'ai mis la 5P08C3 en off et la le moteur demarre mais le ventillateur marche en permanance.
Vieux 28/10/2014, 14h10   #6
MOURAD SPCMAX
essayer avec mon off sans toucher le 95PO8 @++
Vieux 28/10/2014, 14h19   #7
rahmani2008
j'ai comparé les deux immo le tien et le mien et c pareil le probleme ne vient pas donc de l'immo serait il un de probleme de telecodage
Vieux 28/10/2014, 14h28   #8
MOURAD SPCMAX
mon grand dit moi? :)
quel est l'outil que vous avez extrait le 29
Vieux 28/10/2014, 14h37   #9
rahmani2008
je n'ai pas extrait mais j'ai lu la flash 29f400 par obd en utilisant galeto1260
Vieux 28/10/2014, 14h46   #10
smart057
Avatar de smart057
Salut fais a partir de ta flash,100% ok
Type de fichier : rar 29F400BT picasso0281011084 1037364198ORI3coùùecteurs-Patched.rar (163,2 Ko, 17 affichages)
The Following User Says Thank You to smart057 For This Useful Post:
Vieux 28/10/2014, 14h47   #11
smart057
Avatar de smart057
et laisse la 5p08 d'origine!
rahmani2008 (31/10/2014)
Vieux 28/10/2014, 15h04   #12
MOURAD SPCMAX
tre bonne outil pour lu le 29 personnellement je utilis mpps V16,mon ami je suis toujours utilisé immo off avec cette ecu sans souci passe impeccable comme ce mec la !!!!à condition que!!! :) sans toucher le 95P08 signifier dumo 100% off
Vieux 31/10/2014, 16h17   #13
rahmani2008
merci bien;j'ai remis le fichier d'origine de l'eeprom 5p08,j'ai relu la flash29f400,j'ai comparé les dump et je trouve qu'ils sont tous identiques donc pas de probleme sur ce coté. reste maintenant l'essaie peut etre c pour demain.
Fuseau horaire GMT +1. Il est actuellement 03h49.
