Vieux 07/01/2015, 04h09   #1
Pierre Shelly
Avatar de Pierre Shelly
Pierre Shelly is on a distinguished road
Par défaut BMW INPA + 140+2.01+2.10 Cable to activate BMW remote windows up
Plug BMW INPA cable into the USB port on your laptop (Windows XP system would be preferred), install INPA driver and then NCS Expert 3.1 software.
Here is the procedure to show how to do the coding:
Step 1. Start by creating a blank “FSW_PSW.MAN” in the WORK folder.
Step 2. Open NCS Expert.
Step 3. Select the appropriate profile
Step 4. Click on VIN/ZCS/FA, select your chasis, and then select the appropriate ECU (I think EWS in the E39s case)
Step 5. Click back
Step 6. Click on “process ECU” and select the GM3.
Step 7. Click the button to read the ECU data.
Step 8. Go back to the work folder, and there should be an FSW_PSW.TRC file that has data only from the GM3. In there will be a line that says “KOMFORTSCHLIESSUNG_FB”. Under that it’ll say “nicht_aktiv”. Change that to “aktiv”.
Step 9. Click file>save as> and then where it says file type, change it to “all”.
Step 10. Save the file as “FSW_PSW.MAN” and say yes when it asks you to overwrite.
Step 11. Now back in NCS Expert, change the job type to “SG_CODIEREN”
Step 12. Hit execute job.
You should now have convenience closing via remote.
Pierre Shelly est déconnecté   Réponse avec citation
The Following User Says Thank You to Pierre Shelly For This Useful Post:
pat62141 (11/01/2015)
qui a testé remote master ? mustauto programmation & synchronisation de clé 1 02/02/2013 17h57
CAN CARDX + Cable 254 HighSpeed + Cable 1054 LowSpeed TR-DELIGHT Vente, Achat, Echange 0 17/06/2012 01h47
remote control passion-auto programmation & synchronisation de clé 5 03/12/2011 22h13
Fuseau horaire GMT +1. Il est actuellement 10h42.
