Vieux 25/11/2015, 14h21   #1
soustourou
Avatar de soustourou
Pouvoir de réputation: 26
soustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud of
Par défaut Pas de lecture bsi citroen
bonjour a tous j'ai un probleme de lecture des bsi des citroen la derniere fois c'etait une xsara essence et aujourdh'ui un c8 voici les jpeg du diag
merci a tous
Type de fichier : jpg C8.jpg (100,0 Ko, 25 affichages)
Type de fichier : jpg C82.jpg (100,4 Ko, 19 affichages)
On a souvent besoin d'un plus petit que soi
soustourou est déconnecté   Réponse avec citation
Vieux 25/11/2015, 15h44   #2
doud77
Avatar de doud77
de ce que je vois le probleme de com nest pas juste avec le BSI de facon générale avec la plus part des calculateurs...
tu rentres bien caque fois les bons numeros demandés: vin, opr, dam,...utiles pour la reconnaissance des modules par ton lexia...
Vieux 25/11/2015, 16h49   #3
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Ensure you have entered the correct RPO !!
Simple est déconnecté   Réponse avec citation
Vieux 25/11/2015, 17h23   #4
marcusbilly
Avatar de marcusbilly
Pouvoir de réputation: 37
marcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond reputemarcusbilly has a reputation beyond repute
faire un diagnostic teste par calculateur pas teste globale
marcusbilly est déconnecté   Réponse avec citation
Vieux 25/11/2015, 17h43   #5
mysterauto
Avatar de mysterauto
mysterauto is a jewel in the roughmysterauto is a jewel in the roughmysterauto is a jewel in the roughmysterauto is a jewel in the rough
hello simple!
what is RPO?
thanks
mysterauto est déconnecté   Réponse avec citation
Vieux 25/11/2015, 21h19   #6
Larson92
Avatar de Larson92
Larson92 is a jewel in the roughLarson92 is a jewel in the roughLarson92 is a jewel in the rough
cela m'est deja arriver
essaye avec pp2000 tu prend l'equivalent
c8 tu prend 807
pour moi sa a fonctionner
tiens nous au courant
Le savoir n'est rien si le savant n'a pas la noblesse de le partager...
Larson92 est déconnecté   Réponse avec citation
Vieux 25/11/2015, 21h31   #7
soustourou
ok merci a tous thanks pour notre ami simple je verifie tout ça demain et je vous tiens au courant
Vieux 25/11/2015, 21h49   #8
soustourou
j'ai pas pu attendre demain j'ai été tester maintenant et je confirme je l'ai fais passer pour un 807 et tout est ok merci encore
modo marquer comme resolu merci
Vieux 26/11/2015, 01h34   #9
Simple
Avatar de Simple
When you start DiagBox, it reads the VIN, or you can enter it manually, then when you start Lexia the first thing it asks you for is the RPO..
The RPO is a number that is written on the Driver's door when you open it, below the tyre air pressure. It denotes the manufacturing date.
If you enter wrong number you get wrong information but if you enter out of range number then you get NO DATA..
lecture sid 803 karera 1 Réparation & Programmation des calculateurs 4 01/09/2015 19h31
lecture ecu Actif-Car Flasheur de calculateur 3 08/01/2014 22h37
Citroen Lexia 347.19 + Citroen C5 2001-2008 Multilingual TAGRART LEXIA, PP2000, DiagBox 0 16/11/2012 17h48
lecture citroen c3 siemens sid804avec kessv2 ou bootmode? BilChip Chiptuning 4 17/11/2011 21h47
Fuseau horaire GMT +1. Il est actuellement 21h09.
