Hello all,
It is regrettable that Maitresox does not intend to post DBox v7.83 update; I appreciate his hurt.. But the main principle of forums is to exchange information and help others build experiences and possibly become "virtual" friends. Let's stick to this one at least... Hence, for the benefit of all, the Download link and Password for DiagBox update v7.83 (8.19) are in the attached "DiagBox_7.83_Readme.txt" file .. Remember, this update is applicable only if you already have DiagBox v7.82 installed. Please remember, this software is provided as is; for personal, educational and experimental use to upgrade from DiagBox version 7.82 to 7.83 only. I hold no responsibility for any illegal or improper usage. You install this software at your own risk. Enjoy, Simple; |
Pouvoir de réputation: 14 ![]() ![]() ![]() |
I have just updated mine, that's run perfecly on 207 and 308. thanks Simple !
Well done, that's nice to hear.
My understanding is that these 207 and 308 cars are the most difficult with compatibility.. |
Works on 206 1.4L hdi 2004 with Diagbox-pp2000 on win8 x86 also !
merci mon ami
Update 2, 20 Jan 2016:
I have packaged the Engines (153mb) from DiagBox v8 into the file "DBox_Engns.exe". They are not essential, but I thought I will do that since we are using v8 updates. Link in the attached file. If someone wishes to try it, be my guest, at your own risk (you can always stop the services delete the new folders and rename the original folders back). If the installer requests overwrite permissions, then you have forgotten to rename the original folders or you are doing it twice. It worked fine on my computer, but it was a quick one without much thought or testing. Please remember, this software is provided as is; for personal, educational and experimental use to upgrade from DiagBox version 7.82 to 7.83 only. I hold no responsibility for any illegal or improper usage. You install this software at your own risk. Enjoy, Simple; |
| The Following User Says Thank You to Simple For This Useful Post: | yoyomartin2003 (12/11/2017) |
Just for information, I have just installed DiagBox v8.01 using DiagBox v7.xx profile, it was not difficult, but a little lengthy, and it seems running fine.
I may write the process if all is well. Simple |
Hello simple can you make of the tékécodage with the new version.
Good evening |
on peut dire un grand merci a simple si vous avez un problème avec diag box vous pouvez lui faire confiance c'est un professionnel comme maitresox
Salam sami, I did not try it on the car, I only installed and ran it. First I will try the 8.02 update (may be sometime next week), I will see what problems do I have and take it one step at a time..
It looks exactly the same as 7.xx but it feels a tiny little bit quicker. In any case, if you replace the Engine with the one I posted yesterday, you already have (more or less) and equal to V8.xx.. On another note, there was someone who suffered from (id0479- M-Not Found).. This happens on VirtualBox installations, because the Appachi service did not start. The solution: Ensure you have VC++ 2008, it is looking for VC90.CRT" version="9.0.21022.8, but it does not matter you can install the latest.. Then, create a Batch file "DiagBox.bat" on the desktop and write the following inside it.. ............ cd "C:\APP\ddc\opt\apache\bin\" start httpd_ddc.exe Cd "C:\AWRoot\bin\launcher\" start LctPOLUX.exe ............ This will start the Appachi task, then will fire DiagBox.. I tried it and it works... |
Hello, I made the MaJ of Diagbox 7.62 verses 7.66 Everything it very well passed: the installation and the activation. The problem it is that the télécodage is impossible with the version 7.66 with the version 7.62 the télécodage could make it. Try made on my Peugeot 2008 1.6 hdi year 2015. Pc with Windows 7 ultimat. anti virus and adorns fire Windows disconnected permanently, no connection to internet during the updates (of Maitresox until 7.76 and Simple 7.83 and during the diag on the vehicle.
I uninstalled several times and reinstalled since 7.01 and always the not functioning from 7.66 even by going 7.83 (test on the vehicle after every update). Thank you for your solutions thanks to Maitresox and thanks to Simple for all the work carried out for the updates. Today I uninstalled everything and reinstalled until 7.62 |
#12 | |
merci encore pour ton travail
Veuillez donner suite à votre diag et à la résolution du problème !! un petit merci ne coûte rien . |
@Samii1955,
How are you with Computers and Software? can you work your way around? I don't think your problem is with Windows? I noticed some structural requirements when installing 7.66, like .NET 3.5 SP1 but this may be related to the running not the functioning. Your issue could be related to a faulty/missing software module or communication through Firmware. DBox 7.66 comes with Firmware 4.3.4, may be you want to try that first. If it does not work, you have to look into the updates from 7.63, 64, 65 and 66 to find where does it fail, then it can be investigated to find why? Good luck. |
bonjour voila je viens d installer la mise a jour sans soucis mais simple poste "DBox_Engns.exe". en deuxieme poste a quoi sert il doit je l installer un grand merci pour son travail si quelq un peu repondre merci a tous
je comprend aussi qu il a su installer le 8.01 et qu il partagera peu etre |
#15 | |
Hope you are fine? Any news about your tests on v8.xx? What are the main differences between v7 & v8? What is the reason we are in v7.83, while the original is v8.19? Do you think we could jump and follow the v8 updates in the future? If yes, what will be the added value in term of performance? Thanks in advance for your feedback. At one stage, we will need to jump to v8.xx, right? |
| DiagBox v7.77 update | Simple | LEXIA, PP2000, DiagBox | 1 | 21/09/2015 05h40 |
| diagbox ask for update | Chumovoy | LEXIA, PP2000, DiagBox | 0 | 10/07/2014 16h56 |
| Diagbox update 7.44 to 77.45 | fufounet | LEXIA, PP2000, DiagBox | 5 | 23/06/2014 11h57 |
| Diagbox update 7.33 to 7.34 | fufounet | LEXIA, PP2000, DiagBox | 5 | 24/02/2014 01h16 |
| diagbox update 6.32 | deedee | LEXIA, PP2000, DiagBox | 0 | 23/12/2012 22h15 |
