bonjour je souhaiterais acheter renault ecu tool . j aurais besoin d avis sur ce produit sur ce qu il fait .est ca que c un bon produit .fait il les carte renault sans precodage merci
| The Following User Says Thank You to nas33 For This Useful Post: | michel972 (03/05/2020) |
![]() Date d'inscription: avril 2012
Pouvoir de réputation: 20 ![]() ![]() ![]() ![]() ![]() ![]() |
fait l'install et tu verra ce qu'il fait http://www.immo-tools.lt/site/files/...t_ECU_Tool.rar |
Tu as pleins d'info et d'avis déjà sur le forum a ce sujet...oui très bon outil. EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code) IAW 6R.20 - Read/Write TMS370 EEPROM IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code) VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN KANGOO II (2007-2012) - Key Programming, Change VIN MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN MASTER III (2010-) - Key Programming, Change VIN WIND (2010-2013) - Key Programming, Change VIN, Learn ECM TWINGO II (2007-2013) - Key Programming, Change VIN, Learn ECM TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN |
| The Following User Says Thank You to Mathieu35500 For This Useful Post: | michel972 (03/05/2020) |
| Renault ecu tool | Maybach | Programmeur de clé | 7 | 02/04/2016 22h56 |
| Renault ECU TOOL | tintin421 | Vente, Achat, Echange | 6 | 09/03/2016 16h28 |
| avis sur vw dashbord tool | nas33 | Compteur kilométrique | 0 | 23/11/2015 23h40 |
| avis renault ecu tool pour direction assitée? | walteck | Renault, Dacia, Nissan | 9 | 09/11/2015 22h38 |
| demande d'avis sur x-tool | mouss35500 | Compteur kilométrique | 19 | 30/08/2015 00h47 |
