| Autoradio et Navigateur GPS Astuce, dump, aide pour décodage d'autoradio et navigateur. |
Hi friends
I need the PCV connections to read a MC68HC05B16. I've allready seen this in the forum a time ago, but now I can't find it. The problem is that the mcu file is not the original one. So I need the connections to read the file. Regards |
#2 | |
Pouvoir de réputation: 19 ![]() ![]() |
read a MC68HC05B16. |
Pouvoir de réputation: 22 ![]() ![]() ![]() ![]() ![]() |
code adres is $01 and $02
timer adres is $0A =00=reset timer;$0A=01=code disable |
| Connections bdm100 pour marelli | k.emra | Programmateur de composant (flasher) | 5 | 23/03/2017 23h21 |
| Check power and connections K-Tag | leraj | Programmateur de composant (flasher) | 3 | 19/02/2015 12h20 |
| connections au BDM100 | rahmani2008 | Programmateur de composant (flasher) | 2 | 14/08/2014 10h50 |
| code radio pour radio ford V | bbatman | Autoradio et Navigateur GPS | 8 | 10/05/2014 15h28 |
| Car radio vw | hedi makhlouf | Autoradio et Navigateur GPS | 1 | 17/04/2011 08h06 |
