Pouvoir de réputation: 17 ![]() |
Hi friends
I have damaged the eproom 95320 and now I can not read the original file. It is from a Peugeot 208 1.6 HDI, 2014. If I get a file from a compatibile ecu and change the teu chassi number, is it possible to solve The problem? Thanks HugoPinho |
Pouvoir de réputation: 64 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Hi,
Yes there is no problem ! Just find a clear of this ecu and change vin at offset 0x031
>> RocketDump << Logiciel Immo OFF/Immo vierge/Airbag reset/extraction code PIN, ... |
Thanks!
Can anyone have a cleared tested dump to share? 98 127 133 80 Bosch 0 285 012 924 RGB A9 C 08 CEM00 Hugo Pinho |
#4 | |
Guest
Messages: n/a
Try this and report if you want Good luck |
