| Transponder, code pin Vos questions et réponses concernant les utilisation de transponder, l'extraction de code pin ...etc |
j'ai besoin du code pin du bsi sagem de ma citreon C5 ayant HC912
![]() Date d'inscription: mars 2015
Pouvoir de réputation: 20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
code pin est 6B7B ou B7B6 KM 319431 |
merci j'essaye
| The Following User Says Thank You to say882 For This Useful Post: | mousoullis (16/01/2018) |
6B7B code pin correct essai ok
essayer clic thanks
| The Following User Says Thank You to redou28 For This Useful Post: | mousoullis (16/01/2018) |
| code pin citroen c5 | aimanj750 | Transponder, code pin | 7 | 02/08/2015 16h46 |
| code citroen please | Missamissi | Autoradio et Navigateur GPS | 6 | 10/02/2013 20h03 |
| code pin citroen | baste59 | Transponder, code pin | 3 | 25/12/2012 23h44 |
| code pin citroen c4 | baste59 | Transponder, code pin | 2 | 02/03/2012 15h48 |
| Citroen pf1 (a) car code | mourad44 | Autoradio et Navigateur GPS | 4 | 17/08/2010 05h12 |
