| Vente, Achat, Echange achat, vente ou echange de matériel, logiciel ...ect passez par ici. |
software dpf egr remover V3 2016 80 euros la licence par pc (paypal) il couvre de nombreux ecu
![]() Date d'inscription: février 2017
Pouvoir de réputation: 12 ![]() ![]() ![]() ![]() |
Quoi comme type d'ecu ?
ecu testé mais il en prend d'autres.
BMW 120d 2009 edc17cp02 egr off (OK) Peugeot P406 edc15c2 egr off (OK) Peugeot P407 edc16c34 egr off (OK) Golf 6 PCR 2.1 egr off (OK) Passat B6 EDC17CP20 dpf off (OK) Citroen c4 1.6 hdi edc16c34 egr off (wrong solution)must use Peugeot (Solution 2) Ford Galaxy 2.0 tdci SID206 egr off (OK) Clio 1.5dci egr off (OK) audi A3 with pcr 2.1 for dpf (ok) suzuki 1.9 dpf (ok) peugeot edc17c10 dpf (ok) Audi a4 2.0 tdi edc16u31 egr off (ok) peugeot 308 edc16c34 dpf (ok) volvo s60 edc16c34 version switch (ok) Denso Mitsubishi DPF - Processor 7058 and 7059 (OK) Alfa 159 edc16c39 egr (OK) Opel Zafira edc16c39 dpf (OK) MB E320 w211 EDC16C2 DPF Type 1 don't work Type 2 DPF OFF ok. Opel vivaro 1.9dci EDC15C2 Egr off ok with disconnected egr plug. EDC15C2 with Citroen Dpf remove solution - ecusafeV2 with citroen solution is OK. vw ppd1 dpf ok, benz edc 16cp31 dpf ok, vw edc 16u1 egr ok, pcr2.1 dpf ok. pcr 2.1 egr ok. fiat/opel edc16c3 and edc16c39 dpf ok 635d with edc16cp35 and works Very good with dtc off. mazda 3 EDC16C34 - with ecu 0281011995 (OK) mazda 3 2007 1.6d edc16c34 dpf solution -(OK) Audi A4 EDC17CP14 DPF Off Audi Q7 EDC16CP34 DPF Off VW Touareg EDC16CP34 V6 DPF Off Renault Scenic EDC16C3 V1 DPF Off (How to know the version you need ? ) BMW 320D EDC16C35 DPF Off BMW EDC16C35 DPF EGR OK PEUGEOT DELPHI DCM3.5 DPF OK AUDI A1 SIMOS PCR 2.1 EGR DPF OK mazda5 2006 2,0 81kW DENSO dpf (OK) renault edc16C03/9 DPF OK WV Transporter 2006 2,5 96kW EDC16U34 DPF Generic Switch (OK) marelli mjd8f2 - OK Opel Vectra 1,9DTi 16c39 dpf off= (OK) Ford S-Max 2007 SID 206 EGR off= OK Fiat 500 mjd8f2 DPF OK delete sensor Fiat 500 mjd8f2 EGR OK Fiat Bravo 2008 EDC16C39 EGR OK 307 SID 803 DPF ok with solution 803A EGR Vectra edc16 - one switch OK audi A4 2,0 edc 16u31 dpf off=OK caddy 1.9 edc 16u34 egr/dpf off=ok caddy 1.6 simos pcr 2.1 egr/dpf off=ok Hyundai Santa Fe 2008 edc16c39 EGR OFF P0489 EGR Disconnect ---- delete ok DPF OFF error P2002 P0473 --- delete OK pcr2.1 egr done ok zafiza edc16c9 dpf ok Ford Galaxy 2008 SID206 DPF/EGR= OK |
Croyez moi ce sera vite amorti :D
Car SoftWare Provider
Pouvoir de réputation: 204 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Malheureusement Winols reste le meilleur, ce soft n'efface pas les DTC et ne fait pas aussi le cheksum, ce n'est pas une solution fiable.
http://www.mod-file.com FAP/EGR/DFP/O2/Immo/ |
Biensur que ols reste le meilleur mais il faut payer des gens comme toi pour faire des dpf qui bien souvent peuvent etre fait par ce soft.c'est pas ecusafe ou volta,ce soft est plus abouti.
merci pour ton intervention mod-file :D |
avec quelle interface ?par obd? |
Pouvoir de réputation: 79 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
C'est le MTX dpf remover ,
50€ avec notre ami Milanesan de chez Mhh
Pas de "Thanks" plus d'aide! |
c'est le soft de ASC et si c'est milanezu de mhh il les vend 80 euros il y a 2 softs .
non il modifie les fichiers une fois lu par obd.
c'est le soft de http://www.ecudecoder.com en version 2016 |
software old...with many bugs...play with this...i wait after that to contact me for reppair your ecu
Decidement tout le monde s'acharne...! ca derange..?
pas mal de gens l'utilisent et ormis le fait que certains boitiers marchent pas, le pire c'est un voyant dpf ....c'est valable meme pour swiftech etc... arrétez de raconter des conneries c'est invroyable ca... Teamtuner is jesus christ on all forum :D |
et le pire c'est que ces gars utilisent volta ou ecusafe qui sont 100x moins performant bref...si ca concerne pas la vente merci de pas commenter bêtement..
#15 |
big differences between versions mon frere...
old versions many bugs...i tested all...belive me |
| dpf egr remover 3.0 (2016.2) | rosaire974 | Chiptuning | 1 | 27/03/2021 15h37 |
| http://www.mtx-electronics.com/prodotti/Software:dpf-remover | television | Flasheur de calculateur | 3 | 18/05/2017 18h08 |
| sirius remover software | miloud_slt2014 | Immobilizer dumps/solutions | 1 | 05/02/2017 23h57 |
