hi
i need help for this ecu airbag-- audi a4 year 2002 ecu:8E0 959 655 B this is original vin:WAUZZZ8E33A119657 this unit was not the origin of the car was put in another car, but now gives these errors. delete the machine, but walks a little time and the error appears again. I think it should be the number of chassis that is not recorded in this unit, how to solve this? Address 15: Airbags Control Module Part Number: 8E0 959 655 B Component and/or Version: Airbag 8.4EP 2000 Software Coding: 0010602 Work Shop Code: WSC 01007 2 Faults Found: 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent 01794 - Control Module - Incorrect Chassis (VIN) Number 000 - - - Intermittent |
| The Following User Says Thank You to ROG3R For This Useful Post: | alhayate10 (19/10/2013) |
![]() Date d'inscription: décembre 2008
Pouvoir de réputation: 21 ![]() ![]() ![]() ![]() |
Voila ce qui te faut
| The Following 2 Users Say Thank You to sidj For This Useful Post: | alhayate10 (19/10/2013), ROG3R (28/03/2009) |
hi
problem is not crash. thank you |
| The Following 2 Users Say Thank You to ROG3R For This Useful Post: | alhayate10 (19/10/2013), sidj (28/03/2009) |
ok sorry
It is what your problem |
| The Following User Says Thank You to sidj For This Useful Post: | alhayate10 (19/10/2013) |
2 Faults Found:
les codes defauts indiquent que tu a un probleme de communication entre le boitier d'airbag et la voiture, je dit la voiture car j'ai jamais regardé le schema d'airbag de cette voiture alors je sais pas vers quelle composant il communique ( calculateur moteur, compteur ou boitier multifonction) a toi de voir
| The Following User Says Thank You to ricards99 For This Useful Post: | alhayate10 (19/10/2013) |
thank you all
i resolv my problem
