Vieux 05/04/2018, 15h54   #1
sandy976
Avatar de sandy976
sandy976 is a name known to allsandy976 is a name known to allsandy976 is a name known to allsandy976 is a name known to allsandy976 is a name known to allsandy976 is a name known to all
Par défaut Code apv renault trafic
HELLO
HELP !
je cherche un code pin par le dump de la 95080 de l'UCH sur un trafic UCH N3 X83 G2005
PUIS JE AVOIR DE L'AIDE ?
en effet, suite crash PC plus de soft fonctionnel !
merci d'avance,
sandy
Type de fichier : bin 95080 GALEP.bin (1,0 Ko, 37 affichages)
sandy976 est déconnecté   Réponse avec citation
Vieux 05/04/2018, 15h59   #2
verbatime
Avatar de verbatime
verbatime is a name known to allverbatime is a name known to allverbatime is a name known to allverbatime is a name known to allverbatime is a name known to allverbatime is a name known to all
code pin :F9 A8 ED 06 F2 DB
VIN :VF1FLA******993
ISK code :90 65 71 2F 40 D2
verbatime est déconnecté   Réponse avec citation
The Following 7 Users Say Thank You to verbatime For This Useful Post:
jphp (06/04/2018), nimbus (05/04/2018), S-keys (05/04/2018), sandy976 (06/04/2018), seadoo831 (05/04/2018), vortex (05/04/2018), yvespapou (06/06/2018)
Vieux 06/04/2018, 17h34   #3
sandy976
Avatar de sandy976
Par défaut DD
Envoyé par verbatime Voir le message
code pin :f9 a8 ed 06 f2 db
vin :vf1fla******993
isk code :90 65 71 2f 40 d2
merci pour ton aide, je ferai l'apprentissage lundi
Vieux 06/04/2018, 19h16   #4
hatem006
Avatar de hatem006
Pouvoir de réputation: 23
hatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud of
je confirme aussi code pin+vin+isk code
hatem006 est déconnecté   Réponse avec citation
Vieux 06/04/2018, 21h43   #5
Zak78
Avatar de Zak78
Zak78 is on a distinguished road
Salut verbatime , peut tu me dire avec quel outil à tu recupeé le code APV ? Merci
Zak78 est déconnecté   Réponse avec citation
The Following User Says Thank You to Zak78 For This Useful Post:
Mohamedali27 (06/04/2018)
Vieux 06/04/2018, 22h07   #6
Mohamedali27
Avatar de Mohamedali27
Mohamedali27 is a glorious beacon of lightMohamedali27 is a glorious beacon of lightMohamedali27 is a glorious beacon of lightMohamedali27 is a glorious beacon of lightMohamedali27 is a glorious beacon of light
Tu peut le récupérer avec le logiciel Truecode , et d'autres.... si vous avez une liste d'outils à prix corrects pour les code apv je suis prenneur.
Mohamedali27 est déconnecté   Réponse avec citation
The Following User Says Thank You to Mohamedali27 For This Useful Post:
Zak78 (06/06/2018)
Vieux 06/04/2018, 22h41   #7
Envoyé par Zak78 Voir le message
salut avec renault clip tool ===> https://1fichier.com/?sc1bdvo0w4
pass en MP
@bon week end
Dernière modification par jphp ; 06/04/2018 à 23h02.
hatem006 (06/04/2018), Mohamedali27 (09/04/2018)
Vieux 06/04/2018, 22h56   #8
hatem006
Avatar de hatem006
aussi renault pin extractor
The Following User Says Thank You to hatem006 For This Useful Post:
jphp (06/04/2018)
Vieux 06/04/2018, 23h06   #9
exact renault pin extractor RPE ===>> https://1fichier.com/?tcr4ceqzce
pass en MP
@+ bon week end
Dernière modification par jphp ; 06/04/2018 à 23h19.
Vieux 06/06/2018, 16h57   #10
Zak78
Avatar de Zak78
Merci , mais dans un premier temp vous récupérer le Dumps pour extraire le PIN avec (Renault pin extractor).
J'aimerai savoir de quel façon vous récupérer celui-ci sans dessoudé l'eprom donc en passant pas la prise OBD2 ? Et avec quel outils ? Merci beaucoup
Mohamedali27 (24/06/2018)
Vieux 06/06/2018, 22h12   #11
Mathieu35500
Avatar de Mathieu35500
Pouvoir de réputation: 37
Renault ecu tool, AVDI ect....
The Following 3 Users Say Thank You to Mathieu35500 For This Useful Post:
chipshop (07/06/2018), jah83 (07/06/2018), Mohamedali27 (07/06/2018)
Vieux 07/06/2018, 08h01   #12
jah83
Avatar de jah83
Pouvoir de réputation: 245
Et en budget plus accessible renolink
Immo off Renault Trafic II 2.5 dci angelus Immobilizer dumps/solutions 6 18/03/2016 21h42
Abs renault trafic raed83300 Vente, Achat, Echange 0 02/02/2016 20h42
UCH Renault Trafic plouf42 Electronique 5 29/11/2015 22h13
Renault Trafic Nextrick Autoradio et Navigateur GPS 3 01/02/2013 09h48
uch renault trafic 2007 hakimalarme Programmateur de composant (flasher) 0 05/12/2010 19h39
Fuseau horaire GMT +1. Il est actuellement 15h24.
