Vieux 27/10/2018, 19h42   #1
danyparis
Avatar de danyparis
Pouvoir de réputation: 26
danyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud of
Par défaut Pas de démarreur VITO W639 115cdi
J'ai un problème avec un Vito W639 115CDI
Quand j'insere la clé le verrou se débloque bien mais je n'ai pas de démarreur
Au diag 0 dtc mais que je colle le relais du démarreur j'ai un code:
2521 - [8...8] STARTER . Starter attempt without starter actuation
Cela dit en collant le relais manuellement elle ne démarre pas
ZA KRALJA I OTADZBINU, SLOBODA ILI SMRT
danyparis est déconnecté   Réponse avec citation
The Following User Says Thank You to danyparis For This Useful Post:
revo (28/10/2018)
Vieux 27/10/2018, 19h50   #2
wissamsh
Avatar de wissamsh
wissamsh has a brilliant futurewissamsh has a brilliant futurewissamsh has a brilliant futurewissamsh has a brilliant futurewissamsh has a brilliant futurewissamsh has a brilliant futurewissamsh has a brilliant futurewissamsh has a brilliant futurewissamsh has a brilliant futurewissamsh has a brilliant futurewissamsh has a brilliant future
pas de default dans ezs?
regarde les fiches d ezs
mercedes all services(coding repairing installing retrofits). xhorse instant tokens
wissamsh est déconnecté   Réponse avec citation
Vieux 27/10/2018, 19h56   #3
CSYSTEME
Avatar de CSYSTEME
Pouvoir de réputation: 35
CSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond repute
antidemarrage actif
cordialement
The Following User Says Thank You to CSYSTEME For This Useful Post:
revo (28/10/2018)
Vieux 28/10/2018, 10h33   #4
nikita
Avatar de nikita
nikita is a jewel in the roughnikita is a jewel in the roughnikita is a jewel in the roughnikita is a jewel in the rough
beaucoup de soucis d 'elv sur les vito
nikita est déconnecté   Réponse avec citation
The Following User Says Thank You to nikita For This Useful Post:
revo (28/10/2018)
Vieux 28/10/2018, 11h04   #5
danyparis
Avatar de danyparis
Mon ami avait pensé que j'étais un problème de clé il est donc parti en acheter une neuve chez Mercedes
Il a déposé l'EZS et la clé afin qu'on lui soit soit disant reprogramme
Il a tout posé sur le camion quand je mets la clé le verrou de colonne se débloque mais je n'ai pas de démarreur
revo (28/10/2018)
Vieux 28/10/2018, 11h46   #6
tony60
Avatar de tony60
Pouvoir de réputation: 101
Salut je vais suivre de prêt ton poste j'ai le même soucis
The Following 2 Users Say Thank You to tony60 For This Useful Post:
revo (28/10/2018), Tidus97 (28/10/2018)
Vieux 28/10/2018, 12h17   #7
dreamland
Avatar de dreamland
Pouvoir de réputation: 45
Envoyé par danyparis Voir le message
Hello
Ne démarre pas mais démarreur fonctionne ou pas ?
Si démarreur ne fonctionne pas , vérifier son alimentation 12volts et surtout l'excitation si présente .
Ne pas oublier la masse chassis !!!
The Following 2 Users Say Thank You to dreamland For This Useful Post:
alinjadii (28/10/2018), revo (28/10/2018)
Vieux 28/10/2018, 12h48   #8
chipshop
Avatar de chipshop
Pouvoir de réputation: 51
salut ou simplement des relais dans le sam mais sans diag approfondi on veut joué a madame soleil
pas d'aides sans les thanks !!!
chipshop est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to chipshop For This Useful Post:
alinjadii (28/10/2018), dreamland (28/10/2018), revo (28/10/2018), Tidus97 (28/10/2018)
Vieux 28/10/2018, 12h55   #9
salut avec WOW tu dois voir si quand tu tourne la cle l l'info démarreur passe sur ON ou pas , et si tu as l'autorisation de démarrer ensuite tu as un fusible et un relai qui gere la phase de démarrage ensuite il est de quelle année ce vito ???
bon dimanche
The Following 4 Users Say Thank You to jphp For This Useful Post:
dreamland (28/10/2018), revo (28/10/2018), Tidus97 (28/10/2018), vortex (02/11/2018)
EGR OFF edc16c2 Vito w639 jah83 Chiptuning 3 05/02/2016 17h42
Probleme EZS vito W639 Mathieu35500 programmation & synchronisation de clé 24 15/05/2015 08h32
cherche kit de demarrage vito w639 115CDI camacho Vente, Achat, Echange 0 01/12/2014 13h58
Problème démarrage Mercedes Vito 115Cdi bnz2cherbourg Réparation & Programmation des calculateurs 11 18/08/2014 23h10
probleme vito 115cdi remplacement moteur figo95 Mécanique générale 2 24/11/2013 23h36
Fuseau horaire GMT +1. Il est actuellement 13h48.
